Thanks everybody for the feedback. Unfortunately I’ve just blown my power supply for the gun so I’ll need to take a trip to Jaycar ASAP before I’m able to power it up again and record any voltage or resistance at heat data.
Here is a pic of the pcb though...
I agree that resistors will be a waste of battery and a potential problem with the heat they will give out as well.
@Mechatrommer, the link you put up for the buck module looks pretty cool and for 10c I might just splash out and order a few to have a look at.
@Zero999 I may have forgotten to mention that I want the gun to have dual temp options so replacing the element wouldn’t work for me but a temp controller could be an option that would work.
@garethw... the intention for the low temp glue gun is for installing ‘candy glass’. I work in film and television as a SFX technician and the glass we use for stunts etc is no longer made from sugar but is now a brittle styrene material which fractures easily from the temp of a high temp glue gun... I do realise that there are dual temp glue guns available that run on 240v but the advantage of being cordless is HUGE when being on set and replacing breakaway glass between takes... and also yes. I actually relish the challenge of building one myself!!!
[emoji23][emoji23][emoji23]
Sent from my iPhone using Tapatalk
