Author Topic: How to form leads of through-hole components?  (Read 8746 times)
Offline BamburTopic starter
« on: November 16, 2011, 10:12:59 am »
What's the way to form leads of resistors or diodes for example? When I look at assembled PCB's the leads are all round and nice looking. How do they do that?
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
Re: How to form leads of through-hole components?
« Reply #1 on: November 16, 2011, 10:16:42 am »
There is a tool for it. You can find it on ebay for ~2$ or even cheaper from china
http://www.ebay.com/itm/Lead-Forming-Tool-Model-801-/260849384740?pt=LH_DefaultDomain_0&hash=item3cbbd5bd24
Oh, the joy of sending various electronics to silicon heaven
Offline david77
« Reply #2 on: November 16, 2011, 11:54:37 am »
Or just use flat nose pliers, like this http://www.goldschmiedebedarf.de/images/4490-541.jpg
  • Country: hr
    • HackLordSniper
« Reply #3 on: November 16, 2011, 11:58:27 am »
If you want equal bends on all components used then you must use the lead bending tool
Offline david77
« Reply #4 on: November 16, 2011, 12:10:45 pm »
And soon you'll find that not all bends you want can be performed with the special tool and you will go back to the pliers :).
A bit of practice should suffice to become good at bending leads with the pliers.
Of course the lead bending thingy does have it's place if you need to bend a whole bunch of 0,33W resistors, for example.
  • Country: hr
    • HackLordSniper
« Reply #5 on: November 16, 2011, 12:40:01 pm »
I can bend anything with the tool i have, but i will not complain pliers are needed especially for larger components or components which cannot be bended on it (TO220 as an example)
Offline Bored@Work
« Reply #6 on: November 16, 2011, 06:35:18 pm »
For medium amounts of components to bend you use a manually operated Cutbend  http://www.griptech.com/c/tapedaxial/
After that it is automatic machines, ultimately feeding a THT place machine.
Offline sonicj
  • updata successed!
« Reply #7 on: November 17, 2011, 01:18:15 am »
i use a set of cheapo mini round nose pliers from the local craft store.
-sj
  • Country: hr
    • HackLordSniper
« Reply #8 on: November 17, 2011, 06:17:19 am »
That is sweet, but quite expensive
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #9 on: November 17, 2011, 07:10:32 am »
Most local electronics places should sell those plastic lead formers.
http://www.altronics.com.au/index.asp?area=item&id=T1495 $2.20 at altronics :) Why buy off ebay and wait forever.
Offline Flavour Flave
  • Never knowingly unoffensive.
« Reply #10 on: November 17, 2011, 07:48:27 am »
If you're in the EU here's a cheap bending tool £0.99 and free P&P.
http://www.ebay.co.uk/itm/170716401207?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
  • Country: hr
    • HackLordSniper
« Reply #11 on: November 17, 2011, 08:33:47 am »
Its true that most of the shops should have it, but for us in this part of the world ebay is only shop  :)
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #12 on: November 17, 2011, 12:05:18 pm »
I use this tool, model PR2, made in Italy by Elcontrol Enery http://www.elcontrol-energy.net/prodotti/index.asp?mylang=EN&random=706.
See the attached PDF.
You can adjust the distance of the bent legs by directly measuring the distance of holes on the PCB.
You can have symmetrical or asymmetrical position of the component's body.
It's fast and very reliable (mine is more than 25 years old).
Out of topic: this Company designed, I believe in the 70's,  model PS4: a wire stripper and cutter that was copied by many  Chinese cloners, but they carried the cloners to court and they won!
The only difference between the original one and  the clones is that the original works flawlessly,  the clones don't...
EDIT : I've found another tool very similar to the one I recommend:
http://www.hmcelectronics.com/product/HMC-Electronics/N300?refer=topseller
but, for what I understand, it will not ply the leads automatically: you must  ply them with your fingers...
« Last Edit: November 17, 2011, 06:04:45 pm by ciccio »
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #13 on: November 17, 2011, 04:31:20 pm »
Needle pliers, grab the lead next to the body, and push the leg down. Repeat at the other side. That way there is no stress on the body of the component and you get a nice compact bend. If the hole spacing is farther apart you just do it farther towards the body of the pliers.
  • Country: hr
    • HackLordSniper
« Reply #14 on: November 17, 2011, 04:51:16 pm »
And what kind of stress does the tool for forming leads that pilers dont do?
