Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Going over rated Power Dissipation of MOSFET
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Going over rated Power Dissipation of MOSFET (Read 978 times)
help_me_pick_username
Contributor
Country:
on:
November 08, 2019, 02:46:16 am »
I have a 30N06l which is rated for a power dissipation of 79w. If I have adequate cooling, can I dissipate more heat with the MOSFET?
Logged
ejeffrey
Super Contributor
Country:
Re: Going over rated Power Dissipation of MOSFET
Reply #1 on:
November 08, 2019, 04:53:08 am »
79 W is only with the case at 25C -- i.e., perfect heat sinking. Unless you have chilled water cooling you aren't going to be able to even reach 79W.
Logged
wraper
Supporter
Country:
Reply #2 on:
November 08, 2019, 05:14:14 am »
Under realistic (good) cooling don't push more than 30W out of it if you want to have any reliability. And by good I mean either actively cooled with fan or just HUGE heatsink.
Last Edit: November 08, 2019, 05:15:50 am by wraper
Logged
viperidae
Frequent Contributor
Country:
Reply #3 on:
November 08, 2019, 06:12:14 am »
You'd need a heatsink at -15 degrees to run at 79W. The case to heatsink thermal resistance is 0.5C/W, so to keep the case at 25C the heatsink needs to be 79*0.5C lower.
Logged
Contributor
Country:
Reply #4 on:
November 08, 2019, 12:17:17 pm »
Two broken 30N06Ls later, here we are. Thanks for the info guys, at least I learnt some more about how to read a datasheet properly.
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #5 on:
November 09, 2019, 06:03:26 am »
For how long?
(Datasheet also tells: see safe operating area curve, with times given.)
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
