Author Topic: Good quality desoldering station suitable for beginners  (Read 3854 times)
Offline ullbekingTopic starter
« on: March 27, 2018, 04:54:34 am »
Hello!
I've been looking around at the ZD-915 and its clones, in search of a good desoldering station.  I am in the UK, and would like one that has a UK plug and has been certified to work here.
One recommendation in previous threads was the Proskit SS-331 from Farnell element 14.  It sounded great!  However it seems that they only stock the gun now, with no base station.  Their official successor is very expensive, a different brand, and costs about £400.
Would my next best bet be to troll ebay, looking for the SP-1010DR?  Has anybody got any opinions on this?  In the UK, mercateo.co.uk stocks these at about £65... with an EU plug :-/  Is that liable to cause problems?  This seems to be a very "EU" unit, whereas I'm looking for one to use in the UK.
Does anybody have any other recommendations?  Thanks!!
Kindest regards,
Andrew
Offline TuxKey
Re: Good quality desoldering station suitable for beginners
« Reply #1 on: March 27, 2018, 12:51:13 pm »
Hi Andrew,
i'm looking for the same thing and live in The Netherlands.
As i'm starting in the DIY mechanical keyboard modding i plan to de-solder a few keyboards and don't want to mess around with pumps.
But i don't want to break the bank.. so to say..
My research led me to these options..
Hakko FR-301 sold by Batterfly don't know if they sell it with UK plug but i find it to expensive for €300 without vat.
https://www.batterfly.com/shop/hakko-fr-301
my second option was the Aoyue 8800. directly from AoYue distributor in Germany. for arround €120 + €12 shipping to me probably add €10 for you.
http://www.aoyue.eu/aoyue-soldering-hotair-rework-desoldering-station-preheater-repairing/aoyue-desoldering-station-lead-free-solder/aoyue-int8800-desoldering-station-pump-hand-held-type.html
But after reading and asking around for a solution that's around the €100 mark as that seems to be the budget level for desoldering solution
A couple of guys recommended the ZD-915 also reviewed by Dave on the channel..
I was looking at the ZD-8915 for €120
https://www.eleshop.nl/zd-8915-desoldeerstation.html
i wanted to get a portable solution as i don't have lots of space and when i'm done desoldering i want to store it out of the way.
That's the reason why i was looking at the 8800 from aoyue..
But on the mechanical keyboard forum and chat one guy told me to go for something like the SD-915 because replacement parts where cheap / low cost ;-) ..
I did find one negative customer experience regarding the 8800 on amazon.com also someone complaining about getting parts for it.
So it seems a valid argument..
It all depends on the space you have and the budget you have..
If you have the space i would go for the "Aoyue 474A++" checkout the review on youtube where the guy tests the older model and the newer one .. seems you would want the older model.. if possible..
The reason i was looking for it.. was that it was solid build nice metal body and easy to replace parts.
price is €180
If your'e like me and starting of and want to spend as little as possible but have it serviceable i would go for the SP-1010DR from these guys. it's €70 and a new gun is €16,61 new heating element is €6,24
https://www.tme.eu/en/details/sp-1010dr/desoldering-stations/solder-peak/
from what i have read it's wise to grab a spare gun, one spare sleeve , couple of filters and Nozzles
You don't want to be stuck mid work because of a €1,14 nozzle got to wide ...
It's a store in PL nice low prices and i'm sure they can help you with your UK plug needs.. btw no import fees..
After weeks of looking around i think i'm going with this option.. even if it's to big for me.. i'l just move it after each job..
It's not like i'l be desoldering a keyboard every week.. But i don't feel like spending a whole day on a job and possibly most likely ruining a pcb just because i wanted to save €50.. because i good desoldering pump is also arround €10 and not to mention the hassle and time / pain.
The following users thanked this post: xzswq21
Offline ManCave
« Reply #2 on: March 27, 2018, 01:10:31 pm »
Andrew,
EU can be used in the uk with adaptor or just change the plug.
What are you looking to use it for? If you want a cheap and chearful basic device, I once bought this guy
for £8 and it worked pretty good for desoldering most of the stuff including 16-pin DIP packages. It has no temperature adjustment (as you might expect) but might serve your purpose for now and you save some cash to buy a better one when you need it.
Farnell stock it: http://uk.farnell.com/duratool/d01849/desoldering-iron-sucker-40w-uk/dp/2251950
next one up is this one: https://www.ebay.co.uk/itm/80W-Desoldering-Station-230V-480-C-/351206055077?clk_rvr_id=1479967295011&utm_medium=cpc&utm_source=twenga&utm_campaign=twenga&utm_param=eyJlcyI6MCwicyI6OTcyMDIzNywiY2kiOiIwMzg1NDYyZDBkNDM2M2RmOTczMTMwNzQ0NTYwODM0NyIsImkiOiIzNTEyMDYwNTUwNzciLCJ0cyI6MTUyMjE1NjA3NSwidiI6Mywic28iOjE1MDAsImMiOjEwOTU1N30%3D&rmvSB=true
Offline Cliff Matthews
    • General Repair and Support
« Reply #3 on: March 27, 2018, 03:31:39 pm »
Maybe for $10 this fits the bill for some.. (providing it's still available)
Offline TuxKey
« Reply #4 on: March 27, 2018, 04:35:29 pm »
Andrew,
The next up is the one i'm getting from PL for the same price with shipping and your able to get all supplies you might need in the same order ;-)
its £61  basically the same one just re branded
Offline OZ1LQB
« Reply #5 on: March 27, 2018, 06:35:02 pm »
Hi all.
I have the zd-915 for 7-8 years now and it is still good as new.
it has seen heavy use..
BUT if you do buy it you should also buy a handful of tips because
they dont last that long especially if working with leadfree solder..
and if it dies one day i will for sure buy another again.
all the best from denmark
Offline guisveld
« Reply #6 on: August 06, 2018, 06:09:00 pm »
my experiences in desoldering through hole components: I have worked with Hakko 474, Denon SC7000, Aoyue 474+ and the ZD-8915... OK, the built quality of the Hakko is the best. BUT the results, the heating capacity and the suction is the best with the ZD-8915. It simply works better. And if you live in Europe for this price I wouldn't doubt to buy it again:
 https://www.bifelectronic.com/reworking-desoldering/2416-zd8915-bif.html
« Last Edit: August 08, 2018, 02:39:54 pm by guisveld »
