Adding an extra opamp is easy, but I want to squeeze this easy circuit into only two opamps.
The reason is available PCB area. I can afford one SO8 or a couple of SOT23-5 packages,
but adding an extra opamp will force me to switch to SO14/SO16 or add an extra SOT23 package.
I basically have no space for this including feedback resistors that will eat free space even faster.
As for the signal itself,
I want to achieve twice as better scale in further processing by rectifying it with x2 gain.
All circuits are unipolar, working voltage is 5V (3.3V should be also OK).
Maybe I should look for even tinier packages like SC-70 and switch to 0402 for resistors (from 0603)...
Fortunately, I will be able to afford adding an extra opamp... not sure if I should proceed this way.
