I'd appreciate help with what should be a simple design but one I can't get my head around.
I've got a two-wire 3.3V SPI output with a 25MHz clock. I want to pair up consecutive data bits such that I get an analogue level ( 0, 1.1V, 2.2V, 3.3V) at a frequency of 12.5MHz. The DAC output impedance can be high so a simple R2R output is fine. I need three of these for the application and to keep the component count to a minimum.
There isn't a way of getting parallel output from the uP at this speed so changing from the SPI source is not an option and of course I don't have additional signals for thing like a latch or reset input.
Any ideas gratefully received.
