Author Topic: Good soldering station + hot air for under 100€?  (Read 1645 times)
Offline ArnauVF4Topic starter
« on: December 25, 2018, 08:30:35 pm »
Hi, I have always been soldering with a crappy 15€ soldering iron, and I now want to solder more advanced things and do it better. I have a maximum 100€ budget, what should I buy?
I've seen this in amazon and i think its good enough.
https://www.amazon.es/dp/B07BFBL7PV/ref=cm_sw_r_wa_apa_i_F-OiCb3PCZDHV
Thanks
Offline Nusa
Re: Good soldering station + hot air for under 100€?
« Reply #1 on: December 25, 2018, 08:49:19 pm »
It's almost certainly better than what you have. Maybe even adequate for your needs. You're not going to get "good" on that budget.
Offline james_s
« Reply #2 on: December 25, 2018, 11:02:44 pm »
I never recommend those combined units. They are almost always inferior to separate tools, and you will use the soldering iron WAY more often than the hot air station. My advice would be to buy a decent soldering station now, and then save up for an inexpensive hot air station later if you need one.
« Reply #3 on: December 26, 2018, 08:51:39 am »
What soldering station do you recommend then? Thanks
Offline Howardlong
« Reply #4 on: December 26, 2018, 09:22:20 am »
Although most of my soldering is done with Weller (ones with fuses!) I’ve had one of these rebadged under a different name for about eight or nine years. I still use it very regularly, particularly the hot air, for production rework. I estimate I’ve replaced around 1,500 QFNs with it. I haven’t ever had to change any elements. The iron takes Hakko bits.
https://www.amazon.co.uk/Rework-Soldering-Station-Solder-Nozzles/dp/B07GGDZCVG/ref=sr_1_1?ie=UTF8&qid=1545815717&sr=8-1&keywords=898d
« Reply #5 on: December 26, 2018, 12:51:59 pm »
That one exactly  is not in amazon ES (spain) but the one in my original post is similar and it has good reviews, i know its not fancy or anything, but for me its enough i think
Offline 6PTsocket
« Reply #6 on: December 26, 2018, 03:59:32 pm »
Similar units are all over ebay. The main difference seems to be whether the heating element for the hot air is in the handle or in the cabinet.
Sent from my SM-G900V using Tapatalk
Offline ocset
« Reply #7 on: December 26, 2018, 06:04:08 pm »
I think the Aoyue 936 is the cheapest in the world of regulated temperature soldering irons....
https://www.pcb-soldering.co.uk/aoyue-936-soldering-station.html
Offline Howardlong
« Reply #8 on: December 26, 2018, 06:44:20 pm »
Look for 898D. For example...
https://www.amazon.es/Soldadura-0IRHP100-03-Station-desoldadora-temperatura/dp/B07G81ZTMS/ref=sr_1_6?ie=UTF8&qid=1545849798&sr=8-6&keywords=898d
Check it comes with bits and nozzles, I think they all do but worth checking.
Offline james_s
« Reply #9 on: December 26, 2018, 07:20:58 pm »
My favorite is still the Hakko 936 but they were discontinued and there are a ton of inferior fakes out there. I haven't researched the topic lately since I already have an ancient but good Edsyn station but I'm sure there are lots of reviews out there.
