Author Topic: understanding bit shifting  (Read 442 times)
Offline khatusTopic starter
  • Country: gl
« on: April 07, 2020, 08:27:23 pm »
https://www.best-microcontroller-projects.com/pwm-pic.html
Controlling the PIC PWM output
The PIC microcontrollers are very easy to use with PWM as they have built in PWM generators - all you do is set up the relevant control registers
// Timer 2 PIC PWM
PR2=199; // 4 MHz clock -> 5kHz PWM frequency
T2CON = (1<<TMR2ON);
// Initialize Control PIC PWM
CCPR1L = 30; // Initial Duty
CCP1CON = 0x0f; // PWM mode set and 5,4 duty = 0
...and then control the duty cycle:
CCPR1L = j;
Note that the above control only controls the upper 8 bits of the 10 bit PWM module (the other two bits are in a CCP1CON).
Here how does T2CON = (1<<TMR2ON); works??
Offline Siwastaja
Re: understanding bit shifting
« Reply #1 on: April 07, 2020, 08:49:50 pm »
TMR2ON is #defined elsewhere (likely in some .h file provided by Microchip), and hopefully equals to 2. This means, the compiler preprocessor replaces TMR2ON with 2.
(1<<2) means that value 1 is shifted left by two places:
0000 0001
0000 0010
0000 0100
Offline admiralk
« Reply #2 on: April 07, 2020, 09:23:43 pm »
It is not a very good idea to use equality (=) to do that as it could also change all the other bits, if they are not already 0. If you are only wanting to change one bit, you should or (|=) the value. So
T2CON |= (1 << TMR2ON);
is the proper way to do it. That way you only set the TMR2ON bit and leave the rest unchanged.
