Author Topic: LTE2426 problem  (Read 609 times)
Offline elkiTopic starter
LTE2426 problem
« on: November 24, 2023, 04:27:26 pm »
Hello,
I am trying to get + and - voltages from two batteries using TLE2426 with the following setup. Naively, I would expect the initial voltage to be split in two halves, however, I see a very asymmetric output. I am probably missing something very simple. Any ideas would be appreciated!
Offline Jwillis
The following users thanked this post: elki
Offline Zero999
  • 0999
Re: LTE2426 problem
« Reply #2 on: November 24, 2023, 05:57:53 pm »
Is this in real life or a simulator?
If it's a simulator, then it could be an issue with the model having internal nodes connected to 0V.
Connect the negative side to 0V and create a new node, called centre, for the 0V. All plots will have to have V(centre) subtracted from them.
I wish I had Googled. It is a problem with the model. Refer to the thread on the TI forum.
https://e2e.ti.com/support/amplifiers-group/amplifiers/f/amplifiers-forum/1197958/tle2426-spice-model-doesn-t-work-in-floating-circuits
EDIT:
Update:
Here's an example schematic:
Note that the output voltage is referenced to com, LTSpice's alternative to the ground 0 rail.
« Last Edit: October 08, 2024, 05:24:23 pm by Zero999 »
Re: LTE2426 problem
« Reply #3 on: November 24, 2023, 07:21:20 pm »
Thanks a lot! This problem appeared in simulation only. Thanks for pointing me to that known issue with the model!
