Author Topic: GPS antenna cable right beside power cable?  (Read 754 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: February 19, 2020, 03:24:05 pm »
To avoiding to drill to many holes in my ceiling I want to run both my GPS timing antenna RG400 coaxial cable, bundled with the 5 leads (3 phases, ground and neutral). Will it work just fine or do I have to add some extra shielding?
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Offline brabus
Re: GPS antenna cable right beside power cable?
« Reply #1 on: February 19, 2020, 04:23:26 pm »
No problems at all.
« Reply #2 on: February 19, 2020, 11:50:08 pm »
Thank you a lot:-)
Offline amyk
« Reply #3 on: February 22, 2020, 12:53:58 am »
GPS signal is >1GHz, mains is 50Hz.
Online Ian.M
« Reply #4 on: February 22, 2020, 11:13:21 am »
That may well breach local electrical wiring regulations.  Check any requirements for physical separation or barriers between mains power cables and low voltage (e.g. signal) cables.
