Electronics => Beginners => Topic started by: snowzord on December 22, 2016, 05:46:14 pm
Title: GPU caps solder doesn't melt for nothing. Even with the soldering set to 500c
Post by: snowzord on December 22, 2016, 05:46:14 pm
Hi! First topic here, i hope i can get some help :)
First of all, i know that there is a topic similar to this one but i already tried all the options there and no positive results so i'm trying my luck on a new topic.
So, basicly, i am a owner of a 7870 for almost 2 years. Till one year ago it worked fine but one day it started showing artifacts on Windows and on BIOS. After taking it apart and inspecting it i saw a bad capacitator but my "stupid-side" turned on and i decided to put the whole card in the oven for the "famous" oven reflow method. oh gosh, i was so dumb back then.
After several minutes in the oven, all the eletrolytic caps started to pop it looked like a firework show inside my oven. I quickly stopped the oven, opened it and let the card cool down. From that day that i haven't even once inserted the card back on my PC. Some months later (ebay shipping times and so) i got all the caps that i needed to change the bad ones. Picked up a 15€ soldering iron from local eletronics shop, saw some tutorials on youtube and was hoped to fix my card, but no, the solder around the caps legs wouldnt melt for nothing. So after this i opened a topic on a portuguese (i live in Portugal) eletronics forum and they said to me to buy a soldering gun because it was more powerful. Bought one and tried once again to melt the solder around the caps legs but nope, once again the solder wouldn't melt.
Went to back to the shop and bought a solder sucker, desoldering wire and water based flux. Tried all of those 3 and no sucess too. Tried lead-free and leaded solder and no results too.
Since i had a long-term wish of getting into reballing and reflow's and knowing that i would need a rework station I waited till i got it (some days ago) to try again. And once again, the solder would not met, even with the soldering set to 500c (max). Tried both solder again (lead-free and leaded) and it seems that solder "slides" around the legs of the caps and it doesnt joins the existing solder on the cap leg. Already tried too to apply heat on the caps legs with the hot air gun in the rework station (heat set at 150c) and then use the soldering iron to desolder it and no sucess, once again.
Feeling kinda desesperated to confess :|
I hope i can get some help,
Greetings snowie.
Title: Re: GPU caps solder doesn't melt for nothing. Even with the soldering set to 500c
Post by: joseph nicholas on December 22, 2016, 06:56:28 pm
Compter video cards have multi-layers, in order to get the cap out you will need a 100 watt + soldering iron to heat all those layer up to melt the solder.  I tried this one my motherboard and was able to do it with a 60 watt iron but it was a struggle and I don't think I can get the new ones in without more horse power.  Hope this helps.
Post by: SVFeingold on December 22, 2016, 09:11:49 pm
As joseph said, some or all of those caps are most certainly soldered to large ground/power planes and will be a bear to remove. I had a hard enough time removing a micro USB connecter with my 80W Weller station and that was in a phone motherboard. A GPU will have way more mass. I'd say you need to pre-heat the board and get a proper iron. My process in these situations is preheat -> apply flux -> clean tip and add a bit of solder -> keep iron on joint for a few seconds after it appears to melt -> solder sucker. If they're SMD components then wick, but I'd probably break out the hot air for that since you need both solder pads to be liquid. It's a pain but doable. Use the biggest tip you can find. I wouldn't feel comfortable keeping the iron on the joint for more than 5-10s, else you could risk damaging the pad. The old components you don't care about in this case.
And don't set it to 500C, that is waaaay too high. And it's counter-productive - at those temperatures a cheap iron tip will oxidize in no time and cut your heat transfer down by at least an order of magnitude. No bueno. You need more power, not higher temperature.
Since it looks like you're interested in getting serious about electronics hobbying/rework in the future, you might want to invest in a decent solder station.
Post by: Jeroen3 on December 22, 2016, 09:21:51 pm
You will need a pre-heater. Multilayer planes are a challenge.
Post by: wraper on December 22, 2016, 09:28:54 pm
Another one wanting to get on that myth and scam bandwagon.
You need a soldering iron with a large enough chisel tip, preferably wide enough to cover both leads of the cap simultaneously. Also tip must be properly tinned. If you got some nickel plated crap of the tip which cannot be tinned, it will be completely useless. Small conical tips will be useless too, even if of good quality. And better preheat the board. Use leaded solder. For desoldering you could also use Wood's metal (70oC melting point) or something similar. Remains must be removed after that, as otherwise it will impact reliability of the solder joint.
Post by: snowzord on December 22, 2016, 10:42:52 pm
And don't set it to 500C, that is waaaay to high. And it's counter-productive - at those temperatures a cheap iron tip will oxidize in no time and cut your heat transfer down by at least an order of magnitude. No bueno. You need more power, not higher temperature.
hi guys!
huge thanks for all the feedback!
one detail that i forgot to mention, the rework station i got: Baku 702B. It looked pretty decent to me, even a user here on eevblog said it was pretty good for it's price point.
Luckily i have a pre-heater on it's way to my home so that may do the trick!
btw, @wraper can you please explain what you mean with: "Another one wanting to get on that myth and scam bandwagon." I tried to understand but you know, my english is far from perfect in terms of understanding :)
thanks once again :)
Post by: wraper on December 22, 2016, 11:40:10 pm
So I'll post this video again.
https://www.youtube.com/watch?v=1AcEt073Uds (https://www.youtube.com/watch?v=1AcEt073Uds)
Post by: senso on December 23, 2016, 02:50:06 am
BUT ITS NOT A REFLOW..
Its a busted eletro cap.
And as I have already said in another forum, its almost impossible to do that at home without decent tools/spending much more than the card is worth..
Those caps wont prevent the card from booting and displaying an image, if it does not, its dead.
And if you are "desperate" you can pull the old caps and have the leads of them exposed and then just solder your new cap leads to the old cap leads and its done, the extra 5mm of lead will not impact the capacitor job where it is.
Post by: lordvader88 on December 25, 2016, 04:00:04 am
thats what I just thought, if the pads are fine, but the smd part is busted, just try soldering anything at all in parallel over it
worth a try
Post by: JacquesBBB on December 25, 2016, 09:23:11 am
You can try to use this low melting solder paste
http://www.ebay.com/itm/100g-Solder-Paste-Lead-free-Low-Temperature-SMT-Melt-Melting-Point-138-C-SD-528T-/321990643524?hash=item4af8234f44:g:tKQAAOSwvUlWqG6v (http://www.ebay.com/itm/100g-Solder-Paste-Lead-free-Low-Temperature-SMT-Melt-Melting-Point-138-C-SD-528T-/321990643524?hash=item4af8234f44:g:tKQAAOSwvUlWqG6v)
Put some on the leads. Then use your soldering iron. It will melt and it seems that it will also lower gradually the melting temp of the existing solder. Very efficient.
Post by: tatus1969 on December 25, 2016, 10:12:18 am
+1. you can use your oven to preheat the entire board to 120°c, then be quick and you should be able to remove the caps. use a short thick tip, and your iron should be temp controlled. use leaded solder.
Post by: TheAmmoniacal on December 25, 2016, 10:14:48 am
And melt a good-sized blob of solder onto your iron, for making good thermal contact with the joint.
Post by: snowzord on December 25, 2016, 10:45:17 pm
Thanks for all the feedback guys, a huge thanks!
One last question before attempting it: If pre-heat the PCB to 120c, take it out and then turn it upside down to remove the solder with the soldering iron it's there any chance any mosfet or so can fall from the card? I'm asking this because the card will be hot and there may be a chance of that happening (??).
Thanks once again.
Post by: rob77 on December 26, 2016, 12:05:26 am
Thanks once again.
even if you pre-heat to 150 celsius, nothing will fall off the board.
i usually to it this way:
1. put the board facing capacitor down
2. pre-heat whole board with hot air (do not exceed 160-170 celsius - check with thermometer)
3. continue heating with hot air , but the capacitor only - set hot air to 260-280celsius
4. touch the leads of the cap with soldering iron
5. thanks to gravity the cap will fall off the board
