Author Topic: Great Scott's trailing edge dimmer circuit, DC Gnd conneciton to AC Mains  (Read 1412 times)
Offline jwhitmoreTopic starter
  • Software head strays into the Hardware.
I'm looking at this youtube video [1] and the circuit detailed in it. I've attached the screenshot of the schematic.
It's an interesting circuit, but as someone who has worked almost exclusively in DC circuitry I find the sub-circuit in the lower right a bit concerning. The mains AC is switched through the two IRF840 MOSFETs but there is a connection from between the two sources to Ground of the DC Circuitry.  OK so I assume that if there is no connection between the DC Ground and the AC Earth so everything should work just fine but it seems like a mistake could easily happen measuring a voltage relative to Earth.
I was thinking of using a logic level MOSFET [2], but even then instead of using a uC to control the gates, of the MOSFETs, I was thinking to just connect 5V DC between source and gate from a bench top power supply. Then given the mains voltage connected to DC Ground I'd be afraid of blowing up that piece of equipment. I guess DC ground is just riding the sine wave of the AC Mains and so long as it's isolated everything should work, but should I be worried about my bench top power supply? Again so long as I don't plug into 'Earth' connection everything should work. Might be better sacrificing a uC that's easier to replace if this does go wrong.
[1] https://youtu.be/BhQWOv10Oag
[2] http://www.farnell.com/datasheets/2284028.pdf
Offline DannyTheGhost
  • Country: ua
Each time I look on this circuit I see more mistakes, even potentially lethal ones. If I were you, I would not try to build it.
Or it's unfinished circuit, who knows.
Optocoupler, which is driving MOSFETs, does not perform its function - isolation. Even if you supply right-side (with phototransistor) with separate isolated power supply, it still does not include 'turn-off' function for switches, only that 10k pull-down resistor can actually close them, which is bad for transistors.
Returning to your question, if you dare to build it, do not connect anything earthed to it.
The following users thanked this post: jwhitmore
Thanks for your answer. I'll leave that one and maybe keep an eye out.
