The toad green/orange brown ceramic disk caps are reliable and don't just change them out.
Instead- the electrolytic capacitors fail with age - that is the blue and the sea green tubular, grey Shoei in your pics. My practice is to outright change them past past 40 years, they are usually dried out and low value. Radio might motorboat or have weak bass etc.
It better to troubleshoot a bit, if you can say what the radio is doing.
Measuring DCV at IC (don't short probe to the metal strap!) pins can reveal a lot, but we don't know its part number or the radio make/model. That can help too. You can look for the IC datasheet if you don't have the radio schematic diagram.
