EDIT: SOLVED - it is in fact a spare tilt switch included by the seller
(right is just rubber feet)
aliexpress(DOT)com/item/32994824865.html?spm=a2g0s.9042311.0.0.49744c4dgOWW6S
^product in question, all the documentation should be here cos there isn't any in the box
Obviously I'm referring to the "Dongrong SW-200D". I'm an absolute novice who bought this as my first station to put together keyboards. According to Google this is some sort of tilt-switch, maybe I have to install this somehow to get access to the station's sleep function? This is all I found about the sleep/wake on the product page:
About the wake of the handle
Please carefully understand the working principle of the vibration switch in the handle. The ball trigger switch built in the handle, the mounting direction of the ball switch and the rolling direction of the ball inside the ball switch need to vibrate the handle when the direction of the handle is consistent. For example, when the handle is vertical Please move the handle up and down. When swinging the handle up and down, please make sure that the ball inside the handle can trigger the SW wake-up mode, and the force needs to be slightly larger. When the handle is placed horizontally, please swing the handle left and right. Please swing the handle to an angle greater than 30 degrees, so that the ball inside the handle can trigger the SW wake-up mode.
Any help here would be greatly appreciated.
