Suppose in my PCB, due to Ground bounce,the voltage on the reference plane of a PCB, for example, increases by,say 0.2V.
In the PCB stackup, the ground plane (or return plane) is typically a separate layer. Given this, my question is: Would the entire reference plane (the ground plane) experience a voltage increase of 0.2V from 0V (typically), or would the voltage increase be localized to specific areas of the reference plane, particularly around the IC where simultaneous switching noise (SSO) is generated?
If the latter is true, there would be a voltage gradient across the reference plane, correct?
