Author Topic: Drag Soldering tip for Aoyue 968a+ soldering station  (Read 627 times)
Offline djd_ozTopic starter
« on: December 02, 2020, 12:14:55 pm »
Hey there,
Was wondering if you are able to assist me with some recommendations on which tip to use for drag soldering with the Aoyue 968a+ soldering station.
Many thanks!
Offline rstofer
Re: Drag Soldering tip for Aoyue 968a+ soldering station
« Reply #1 on: December 03, 2020, 03:17:34 am »
I use a 1/8" chisel tip.  That is what I use but it isn't right.
https://www.hakko.com/english/tip_selection/work_drag.html
Offline uli12us
« Reply #2 on: December 03, 2020, 04:34:04 am »
The recommended type for drag soldering is the type BCM or CM. The BC or C will work as well. The type with a small hole in it should be better, because you have a small reservoir of solder, with that you can remove too much solder from bridged pins, because the solder flows back to the hole. Or at least should flow, I haven't tested it until now.
