Author Topic: What is the loss of this connector? CB noobie question  (Read 4347 times)
Offline rickselectricalprojectsTopic starter
« on: May 03, 2015, 12:08:22 pm »
 Hi everybody!
I just wanted to know what the loss would be of this connector: http://www.ebay.com.au/itm/N-TYPE-MALE-to-PL259-MALE-ADAPTOR-PLUG-UHF-CONNECTOR-HAM-CB-SO239-ADAPTER-/201052256995?pt=LH_DefaultDomain_15&hash=item2ecfa5fae3
At 477mhz (cb radio frequency in Australia). I want to use this connector so i don't wear out my so-239 connector on my radio and this is probably the lowest loss connector i could think of. So is there a better lower loss connector and what is the loss of this connector?
Thanks! :-+
Offline GreyWoolfe
  • NW0LF
Re: What is the loss of this connector? CB noobie question
« Reply #1 on: May 03, 2015, 12:14:52 pm »
How many times a day to you plan to connect/disconnect?  I very much doubt that you will wear out the connector on your radio unless you cross thread the connector.  I have 30 year old ham transceivers that the connectors look almost brand new on.  Enjoy the radio and, as a friend of mine would say, don't pick flea shit out of pepper.
« Reply #2 on: May 03, 2015, 12:23:25 pm »
I would connect/disconnect probably about 2 times a day as i will have to have the cable going through a door so when i shut the door i will have to disconnect the cable
Offline lapm
« Reply #3 on: May 03, 2015, 01:34:53 pm »
Would be easier just drill hole for antenna cable in wall.  :-+
Electronics, Linux, Programming, Science... im interested all of it...
Offline Nerull
« Reply #4 on: May 03, 2015, 02:12:27 pm »
SO-239 is already pretty awful above 300MHz. The impedance drops in the middle of the connector and generates reflections. If you're worried about loss, put something else on it.
« Last Edit: May 03, 2015, 02:14:45 pm by Nerull »
Offline madires
  • A qualified hobbyist ;)
« Reply #5 on: May 03, 2015, 02:13:08 pm »
If the connector isn't too shabby the loss would be around 0.1 - 0.3 dB, but I would go for a high quality SO-239 with PTFE dielectric (suited for up to about 450 MHz) or a N type connector (up to 11 or 18 GHz).
Offline LabSpokane
« Reply #6 on: May 03, 2015, 05:46:48 pm »
That's typical insertion loss for most common RF connectors. If you're going to doing hundreds of cycles, you really should be looking at a lab duty connector. The cheapies typically are "set it and forget it" deals. The plating will likely go quickly.
Offline Richard Crowley
  • KJ7YLK
« Reply #7 on: May 03, 2015, 05:58:17 pm »
Connecting and disconnecting anything like that several times a day is just asking for trouble. I would put a premium on finding a solution that would keep the connections intact.
If I HAD to do several cycles/day I would use something like a General Radio connector...
http://www.ebay.com/itm/General-Radio-type-874-connector-to-type-N-male-adapter-/201239413811
Offline madires
« Reply #8 on: May 03, 2015, 07:25:04 pm »
... after asking the seller if it's 50 or 75 Ohms.
« Reply #9 on: May 03, 2015, 09:28:15 pm »
We rent and i also dont think my mum would be very happy (i am only 14)
« Reply #10 on: May 03, 2015, 09:38:41 pm »
What about this connector: http://www.ebay.com.au/itm/UHF-female-SO239-jack-to-UHF-female-double-straight-RF-Coaxial-adapter-convertor-/161296121428?pt=LH_DefaultDomain_15&hash=item258dff7e54
I imagine this would have more loss than the pl259 to n type or am i wrong?
  • KJ7YLK
« Reply #11 on: May 03, 2015, 09:56:48 pm »
"Loss" isn't really the issue.  The larger issue up at 400+ MHz is the impedance mismatch through all those cable-connector-connector-connector-radio joints.
The SO-239 connector on your radio is probably more rugged than ANY of the alternatives you are looking at.  I think you are chasing phantoms and should just use it as-is.  You have an excellent chance of making things worse.
