Author Topic: Grounding high frequencies 2  (Read 1000 times)
Offline testtube44Topic starter
« on: August 25, 2018, 06:09:50 pm »
I'm having trouble understanding how to shield high frequencies, if the frequencies are so high, that the ground cable would act like an antenna too. Would it be a bad idea to shield the ground cable ( :wtf:) and connect that shield to ground in a slightly different spot? This should create canceling fields and prevent the ground cable from emitting more radiation. Is this correct, or would it just cause more problems?
« Last Edit: August 25, 2018, 07:03:12 pm by testtube44 »
Offline HB9EVI
Re: Grounding high frequencies 2
« Reply #1 on: August 25, 2018, 06:20:01 pm »
Often the screen of a RF signal cable actually acts like an antenna; that always happens, when the current flow is not fully differential; that's a so called common mode signal with makes the shield of a coax cable radiating RF; the origin is often feeding a balanced system with an unbalanced feed line.
Those common mode signals can be radiated also over the supply lines of an RF circuit - the solution, whereever it might happen are common mode chokes - that's all it needs.
« Reply #2 on: August 25, 2018, 07:05:14 pm »
What if you're not allowed to change the frequency content of the line? Is there any other way to create a canceling field? I think differential pairs (one opposite the other) would do just that.
Offline David Hess
  • DavidH
« Reply #3 on: August 25, 2018, 08:52:20 pm »
Sometimes a tuned ground counterpoise is used but that does not stop the ground from radiating.  Some improvement can be made by using a ground connection which has lower inductance like a braid or strap which is like using the shield of a coaxial cable.
Offline HB9EVI
« Reply #4 on: August 25, 2018, 10:47:36 pm »
a common mode choke doesn't alter or attenuate the frequency content on a signal line, since those are differential currents; if you hook a snapon ferrite onto a usb or an ethernet cable, you are actually filtering common mode signals; the data signals are not affected by the inductance the ferrite forms on the wires.
if you think of differential pairs as a balanced signal line, you have to watch out as well to not end up with unsymmetries resulting in radating signals from the wires. of course this issue is no one-way problem only; missing or incomplete symmetry can cause the signal wire acting as a receiving antenna; that's a considerable topic when designing balanced audio gears, it's all about the common mode rejection ratio
