Hello EEVblog!
I have bought a KSGER T12 soldering station with the black v2.05 pcb from banggood, and I have already done the grounding of the case to PE.
However, I have not yet grounded the secondary circuit (the tip + controller) and I have some questions about this procedure, since I have had trouble finding a detailed tutorial for this.
I have studied the schematics provided by floobydust here
https://www.eevblog.com/forum/reviews/t12-stm32-v2-1s-soldering-station-controller-schematic-etc/msg2467236/#msg2467236 and they say that "PE GND needs jumper or extra wire added!"
I have measured continuity from the GND pin on the controller to these - pins on the mainboard. The first two pictures shows this.
From my understanding any of these pins should be connected to PE to provide ground to the controller and the tip. Is this correct?
If so, is it also correct to use any of the colored connections in the third picture?
