Finally stop quoting your 4mm and 5mm mantra as the only safety metric,
Gyro, you must learn to READ. I have never claimed 4 and 5mm as the
only safety metric. I have always mentioned that the environment must be considered.
Already in my first post I wrote:
"This is a stereo. It's meant for a normal domestic environment, i.e. no excessive humidity or dust. It is not ment to be mechanically abused as power tools are."I have also written:
"The intended use and environment plays a big role in the design and certification process. Equipment meant to be used in a normal office / living room environment is subject to lighter regulations than something meant for use in the kitchen or outdoors or as toys for instance."
But you prefer to be blind for this. Only you can tell why.
Electrical safety has nothing to do with words written on a paper.
Legal safety has something to do with words on paper.
No product will become safe because of words, and no product will become unsafe because we call the product something else.
What makes a product safe depends on the environment and physics. 4 and 5mm
will provide the clearances necessary for normal mains voltages in a
normal office or living room environment, regardless of what is written on any paper or what we prefer to call the product.
The reason the standards increases this distances for certain products is not because we call the product someting else than computer or fax or monitor. The reason they demand more clearance for some products is because they know that those products probably will be exposed to a more demanding environment, for instance people acting stupid. They increase the safety
margin. Not necessarily because the product itself needs it, but because of the expected environment. They don't make a separate standard for every product imaginable. They try to group them according to expected use and environment.
Your computer monitor with 4/5mm distances is considered perfectly safe when you use it as a monitor for your computer in your living room. This monitor will not become unsafe just because you hang it on the wall in the same living room and uses it as a TV together with a TV dongle. According to words written on paper, it is now a TV and should be tested as a TV to be conform with a more demanding standard. Because of this it is
legally unsafe. It is still
electrically safe because it is still used in the environment it was designed for. If you move it to the kitchen or outdoors, you can find it to be both electricall and legally unsafe because the environment is too different from what it was designed for regardless of being used as a TV or a monitor.
But - I don't think you ever will get it.
It seems like it is impossible for you to see the difference between how to find out if an
existing product can be considered as safe to use, and the design process needed to create a new product that will have to follow all legal requirement in today's legislation.
