Author Topic: Gw instek power supply  (Read 648 times)
Offline Shutterdial
« on: March 18, 2017, 11:13:36 pm »
My power supply came  with a short bar.   I'm guessing it shorts out the negative and ground if this is correct Why?
Offline w2aew
    • My YouTube Channel
Re: Gw instek power supply
« Reply #1 on: March 19, 2017, 02:11:39 am »
Because the output is floating. If you want a positive output, connect the bar between ground and the negative side of the supply. If you need a negative supply voltage, then strap the pos output to ground.
I did a video on this:
« Last Edit: March 19, 2017, 02:13:36 am by w2aew »
FAE for Tektronix
