Author Topic: H-bridge motor driver circuit  (Read 291 times)
Offline TantalumTopic starter
« on: December 28, 2024, 01:30:06 pm »
Hello
I have a little project. I need to driver a small linear actuator, like on this picture:
The specs:
- ESP32 Wifi module
- H-bridge motor driver (don't know exactly which one yet, but it doesn't matter)
- 24VDC power over a 20m long cable
- in a waterproof box outdoors
Now the questions:
Q1: Do I need an isolated DC-DC converter?
Q2: Is it advisable to use a surge stopper like a LTC4366 (burns the peak surge voltages in a MOSFET), or are passive protections (Diodes/Movs) enough?
Q3: Is it better to use an opto-coupler on the motor driver input-side?
Thank you for your help  ;)
Offline Siwastaja
Re: H-bridge motor driver circuit
« Reply #1 on: December 28, 2024, 01:38:31 pm »
Q1: No, Q2: No for LTC4366, no for MOVs; what are "diode protectors"?, Q3: No;
but this rises a question of why you think asking those questions make any sense, and what are the things you are missing?
Therefore,
I think this does matter. The design of the motor driver itself is the key.
« Last Edit: December 28, 2024, 01:40:16 pm by Siwastaja »
« Reply #2 on: December 28, 2024, 04:01:19 pm »
Well I was thinking to use a DRV8871 (45V/3.6A max) which seems more than enough for a 12V 0.6A motor like the one I'm using.
Offline Siwastaja
« Reply #3 on: December 29, 2024, 07:03:18 am »
Then the important points are PCB layout and DC link capacitance. A TVS on power input might be a good piece of protection.
What drives the inputs of DRV8871?
