Author Topic: HACK ? Lipo / Li-ion Battery Voltage alarm.  (Read 3240 times)
Offline user1235423643Topic starter
« on: September 03, 2016, 02:50:48 pm »
does anyone know how to hack one of these to alarm at a different voltage
it will alarm if any cell drops under 2.7~3.8V
what about alarm on TOTAL voltage rather then per cell?
and a a bigger alarm total range?    (if the battery total cells was 30v... alarm at 20v)
thanks
specs:
1-8S Lipo/Li-ion/Fe RC helicopter airplane boat etc Battery Voltage 2 IN1 Tester Low Voltage Buzzer Alarm
Features:
1-8S Lipo/Li-ion/Fe RC helicopter airplane boat etc. Battery Voltage 2 in 1 Tester Low Voltage Buzzer Alarm
Use for 1-8S Lipo/Li-ion/LiMn/Li-Fe
Voltage detection precision: +_0.01V.
Unit voltage display range: 0.5~4.5V
Total voltage display range: 0.5~36V
1S test mode voltage range: 4-15V
Low voltage alarm mode for 2-8S
Alarm set value range:OFF~2.7~3.8V
Specification:
Size: 40mm x 25mm x 11mm
Original box: NO
Net weight: 9g
Color: Red
Package Content:
1 x 1-8S Battery Voltage Buzzer Alarm
Offline amyk
Re: HACK ? Lipo / Li-ion Battery Voltage alarm.
« Reply #1 on: September 04, 2016, 12:56:24 am »
You would have to investigate the schematic and see how it senses the voltage. If they're using a discrete voltage reference + divider then you can change the resistors, otherwise if they're using a standard lion protection IC (like a DW01) the voltages will be fixed.
Offline jwrodgers
« Reply #2 on: September 06, 2016, 11:03:20 am »
The reason it alarms if any cell drops too low is because the cell will be damaged if it is discharged below a certain point. (I prefer not to take any cell in my Li Ion battery packs below about 3.1 volts.) If you only monitor the total voltage, you may miss when a cell is being drained too low due to imbalances between the different cells. The pack voltage may still be ok for the application, but continuing to use it with a low cell can lead to damage in one cell that renders the complete pack useless.
I have assumed here that you want to use it with a battery pack to get longer from it, but you may have an innovative application that I have missed, if so I apologise in advance.
« Reply #3 on: September 09, 2016, 09:11:44 am »
so does anyone know how to hack these, or?
