Author Topic: PWM PMIC for hacking up a small display?  (Read 753 times)
Offline joeyjoejoeTopic starter
« on: November 04, 2018, 03:46:25 pm »
I got some SWAG that is a simple LED-backlit case that let's you put in letter and customize a message. Inside is simply two LED trips, a 10Ohm resistor and it runs of 3xAAA.
I'd like to hack it up to get a bit more life, and possibly make it run off a single 18650 with a simple protection circuit and microUSB charging. Also, ditch the resistor for something more power efficient.
I could do a simple 555, but it got me to thinking.. this seems like a straightforward application. Are there existing IC's that have a PWM output, can drive LED's and have a low current? Do they have a name I can search for? Category in Digikey?
(I tried some google-fu for that but got mostly complete LED driver circuit boards or complete LED drivers themselves...)
« Last Edit: November 04, 2018, 04:01:49 pm by joeyjoejoe »
