Author Topic: Surface coating and electrical conductance  (Read 4024 times)
Offline nukieTopic starter
« on: May 31, 2011, 02:04:03 pm »
Hello all, I have a question. Google gives me answer my small brain could not understand, so I need help.
I read that AC current travels on the surface of a conductor. So given two different conductor made out of different material, say brass and nickel. Coat it with gold. Now both have same surface resistance, so what about electrons flow rate ? Assuming both conductors are equal in physical dimension.
« Last Edit: May 31, 2011, 02:06:03 pm by nukie »
Online Zero999
  • 0999
Re: Surface coating and electrical conductance
« Reply #1 on: May 31, 2011, 02:20:02 pm »
It's only true at high frequencies which is why silver plating high frequency conductors is useful in reducing their resistance.
Offline vk6zgo
« Reply #2 on: May 31, 2011, 02:30:34 pm »
A warning on silver plating.
Normal plating as used for sporting trophies,etc has additives to increase the brightness &
durability.
These increase the RF resistance to a higher figure than plain copper.
Special plating is used for RF conductors.
VK6ZGO
Offline Time
« Reply #3 on: May 31, 2011, 05:52:53 pm »
You should read about the skin effect.  Thats the phenomenon you are interested in.
http://en.wikipedia.org/wiki/Skin_effect
All AC currents know this effect it just becomes more apparent from an engineering stand point in higher frequencies.  I believe the skin depth for 60 Hz in copper is about a cm or something.
-Time
« Reply #4 on: June 03, 2011, 03:29:41 pm »
Yes skin effect is what prompted my question.
I was looking at my meter probes and some banana jacks and it got me thinking why some are gold plated while most are chrome/nickel plated. I prefer standard plating, gold would be too soft and wear out too quickly especially around the contact areas.
Now I also understand why those high frequency wifi antenna jacks are mostly gold plated. Thanks guys!
Offline the_raptor
« Reply #5 on: June 03, 2011, 04:06:25 pm »
Gold oxidises less then chrome/nickel AFAIK. It might wear off from frequent disconnection and reconnection but it won't easily build up an oxide layer thick enough to impede electrical current.
In PC repair I have seen non-gold plated connections fail after a handful of years and require cleaning.
Online Zero999
  • 0999
« Reply #6 on: June 03, 2011, 06:03:30 pm »
Then you've completely misunderstood.
Connector are gold plated to improve corrosion resistance and has nothing to do with the skin effect. Copper is a much better electrical conductor than gold and is much cheaper too. Gold plating reduces the contact resistance because an insulating oxide doesn't form on it.
http://en.wikipedia.org/wiki/Electrical_conductivity#Resistivity_of_various_material
