Author Topic: F-SW26 no-clean flux?  (Read 1352 times)
Offline BlastFXTopic starter
  • Country: cz
« on: November 25, 2018, 08:02:29 pm »
I'm ordering new solder and I've noticed the datasheet for Stannol's HS10 which uses the F-SW26 (1.1.2) flux says it doesn't require cleaning.
I was under the impression that F-SW26 was a bit too corrosive to leave on a PCB. Am I wrong or is Stannol?
Offline dangerousamateur
  • Country: at
Re: F-SW26 no-clean flux?
« Reply #1 on: November 25, 2022, 10:58:12 am »
This topic may be old, but I have the same question.
Whats you opinion on this? I still have lots of F-SW26.
Should I prefer F-SW32 or 34?
Offline coromonadalix
« Reply #2 on: November 25, 2022, 05:32:22 pm »
My comments would be :  whatever the flux type or brand
Always do a board clean up
I've seen some corrosion,  residues who create problems in high frequency applications or sensitive high impedances circuits   .... it created some input leakages ....
I never let a board with flux on it, more than 4 hours
I've seen returned boards with corrosion under some parts  one year after assembly ...
my 2 cents
  • Country: at
« Reply #3 on: November 25, 2022, 08:24:25 pm »
Thanks for the answer.
In fact I must say I don't make PCBs, I repair something sometimes... And I do a lot of RC modelling stuff.
I have a feeling that some very old F-SW26 / 1.1.2B I have works better with old parts that have been sitting in the cellar for a very long time.
But I never noticed any corrosion...
Is that whole corrosion issue maybe a thing that just becomes relevant when SMD parts are soldered with a wave machine and the flux can accumulate on the underside, where the flux is not properly cooked?
Maybe not even relevant in hand-jobs?
