Author Topic: How do you waterproof your projects?  (Read 2379 times)
Offline AxlesTopic starter
« on: April 25, 2013, 05:14:16 pm »
Fairly new to electronics, but very new to product design, so would appreciate some help.
I've designed a couple of physiological monitoring devices (Wireless HRM, smallish logging holter ECG) which work great, but are physically susceptible to damage.
What would be the best way to seal the devices up, but still leaving test points to extract the data and to recharge them? The HRM is about the 20x10x10mm and the ECG about 80x30x10mm.
Thanks in advance.
Offline 8086
    • Circuitology - Electronics Assembly
Re: How do you waterproof your projects?
« Reply #1 on: April 25, 2013, 05:18:10 pm »
There's weatherproof connectors available, but the size is an issue.
You could conceivably use a USB connector or similar and pot the whole thing except the connector opening...the worst thing that could happen is the connector rusts or something.
Offline casinada
« Reply #2 on: April 25, 2013, 05:44:32 pm »
In industry and military applications they use what is called a conformal coating. They coat the printed circuit board so it prevents damage from water, dust, corrosion, etc. Most of the appliances come also coated. That makes them very durable but also impossible to repair.
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #3 on: April 25, 2013, 05:44:55 pm »
I deal with this issue on an almost daily basis - it's one of the biggest design challenges in electronics next to thermals.
We make our own enclosures in-house, so I have the luxury of being able to create whatever housing I want.  But in no particular order, what helps me is...
1) Conformal coatings
2) Epoxy potting
3) Waterproof connectors (expensive and only as waterproof as how well they are used - if a customer doesn't plug it in correctly or compromises the water seal, you will still get it back under warranty with a 'I have no idea what happened - it just stopped working' explanation).
4) One trick I really like is to just put a threaded hole in the outside of a housing where a test point is.  Then use an off-the-shelf screw with a rubber washer or o-ring.  When the screw is installed, it will be water tight, but you can easily take it out to get to the test point below.  Just be sure the screw doesn't go too deep and hit the board.
5) Using alternative methods for interfacing.. rather than a wire, you can use a magnet to actuate a hall effect sensor, or you can use an IR receiver which will function through clear epoxy, or you can use radio communication, etc.  This can help eliminate some need for external connectors and wires.
6) Having wires come off the board and pot the whole thing.  It's much easier to seal wires with heat shrink or just by dipping in "liquid electrical tape".  This is very cheap and works for things you would only need to access rarely, like a programming interface for programming in the field.  Dangling wires is not very good for consumer products, though.
7) I also sometimes bring wires out of a potted unit and terminate with a waterproof connector - then I take the mating part of the waterproof connector and just fill it with hot glue to make a "cap" for the waterproof connector to terminate it and keep it waterproof.  Then when you need to access the port, unplug the dummy plug and insert the real mating part in.
You can also use dielectric grease, but it's a pretty shoddy way to create waterproof products... it works if the consumer will never be accessing the unit, though.
« Last Edit: April 26, 2013, 07:30:22 am by Corporate666 »
It's not always the most popular person who gets the job done.
Offline codeboy2k
« Reply #4 on: April 26, 2013, 06:26:10 am »
I've seen these types of medical devices fully enclosed and sealed, and access to recharge and extract the data is via inductive coupling .
Offline peter.mitchell
« Reply #5 on: April 26, 2013, 08:55:16 am »
I generally do inductive charging/powering, IR data transmission, metal piezo buttons - removing most direct electrical connections and insulating switches, then for cables entering and exiting for sensors, standard connections internally, but waterproof cable grommets, waterproofing the enclosure, also, another big thing to remember - use standoffs in your enclosure, keep the board from the edges of the enclosure by as far as you can, so if then enclosure does get water in it, the board won't be sitting in it (hopefully).
