Author Topic: hakko 951 sleep help  (Read 365 times)
Offline sofaires
  • Country: pr
« on: March 30, 2019, 01:42:20 am »
hello everyone, new here on the forum. i need a little help with this station
i changed the temperature and it stopped going to sleep after reaching the set temperature so i looked a few videos that were on another language and i could managed to get it to go to sleep but now it goes to sleep on use or when i put it in the holder.
my question is, is there a setting to make it go to sleep only when i put it in the holder?
i know how to enter the hidden menu and all just need the settings to do that, i really don't want to mess with the settings because they are like an old alarm clock with no indicator of what you are changing and what not.
i appreciate it if anyone knows this settings, thanks in advance!
Offline GreyWoolfe
  • NW0LF
Re: hakko 951 sleep help
« Reply #1 on: March 30, 2019, 04:28:28 pm »
Power off and insert the card.  Hold the up and down buttons together and power on.  Continue to hold until you see 1-C or 2-F, then release.  Press the * button and you will move to the sleep settings.  2 0 on the display means that it will go into sleep mode as soon as it is on the cradle.  if you see any thing else like 2 10 or whatever, pressing the down arrow button should get you back to 2 0.  If that doesn't do it, you might have to use the up button to cycle through all the minutes settings until you get back to 2 0. Then press the * button to save setting.  Hope this helps.
