Author Topic: Commercial name for common headers  (Read 1948 times)
Offline Back2VoltsTopic starter
« on: September 14, 2016, 07:55:26 pm »
Just curious.  I am having a hard time searching on Mouser / Digikey / Newark for common headers which in eBay/Alixpress are normally referred to as male/female pin headers, like
http://www.aliexpress.com/item-img/10PCS-16-Pin-1x16P-2-54mm-Long-Leg-11mm-Single-Row-Female-Straight-Header-Pin/32720206598.html?spm=2114.10010108.1000017.1.otUPry
I know in a purist sense, the female would not be pins, but again...
Offline Jeff_Birt
Re: Commercial name for common headers
« Reply #2 on: September 14, 2016, 11:37:24 pm »
try - http://www.mouser.com/Connectors/Headers-Wire-Housings/_/N-ay0lo?P=1yzmo3uZ1yy4gdp&Keyword=header&FS=True
Jeff, thanks for helping, but it is odd.   If I select "Stocked" and "Socket(Female)" for Gender, and then do "Apply filters" I get only 12 parts, and if I further narrow it to 2.54mm there are only 2 parts.   It does not make any sense to me.
Offline Jeff_Birt
« Reply #3 on: September 15, 2016, 12:43:33 am »
Sometimes the filters do goofy things. I'll sometimes find the part type I want and try to figure out what category it is in and search that category. If that fails I pull out the printed catalog which is much easier to search by picture :)
Offline Brumby
« Reply #4 on: September 15, 2016, 05:14:54 am »
+1
.... and I've seen this on more than one site.
