A lot of scopes have minor issues which are fairly easy to correct. Check the panel controls are set up first properly and try and get a stable single channel trace out of it first. You don’t need a test signal for that. If that fails various forum members here can probably talk you through an evaluation and/or repair.
If you’re new to this, post a picture of the entire front panel with it powered up to see what situation is.
It’s a very nice analogue scope when it’s working so worth pursuing a repair if needed.
