Problem with these parts is you will not be able to see a short. It is a near certainty that out of 100 tries, you will have X number of installations that look perfectly fine but which have a hidden short. Using paste will most likely increase your chances of making bridges. Getting it on there in an even manner is not easy to begin with. And even with soldermask, solder paste does not automatically suck to the pads. Little bits of smeared paste will bead up into little isolated bits of solid solder and potentially cause future problems. Between any of those pins you might have a lot of tiny bits of solid solder that can move if/when the board is cleaned of flux residue. You will never have this problem when pretinning the pads.
Even if you get the paste perfect, you can easily screw everything up when setting the chip down or when applying the hot air if the chip moves from the air or the flux bubbling. If you accidentally smudge the paste too thin during any step, you can easily get the isolated beading problem or complete bridges. Unless you have a lot of IC's to do and you can "get in a rhythm" with the paste, I think you will spend more time trying to use paste while getting a higher error rate.
The downside of pretinning the pads is the solder beads are rounded. And when the flux heats up and mobilizes, the chip can tend to slide off to one side or the other. So on either the pcb side or the chip, you should aim for just a really thin layer of solder just to help wetting. Flux the pads and rub a clean soldering iron tip over it just to silver-flash the pads on, say, the chip half of the equation. But you can always remove the heat and nudge the chip back in place as many times as you need to, before the solder starts to reflow, since there's no paste to smudge.
So there are downsides, but I prefer to pretin the pads. Personally, I have a lower bridge rate when doing it that way. Which ends up saving time, overall. I feel like people go out of their way to find a use for solder paste. Outside of its intended purpose. And it's not really that great.
