Author Topic: My First C program.  (Read 3335 times)
Offline brucehoult
Re: My First C program.
« Reply #25 on: April 22, 2022, 05:57:21 am »
C seems to be very nitpicky about  spaces. I tried adding spaces in the macro and it refused to compile. Is there a rule about where spaces can and cannot go?
That's absolutely incorrect.  Almost all spaces in a C program can be removed with no ill effect, and more whitespace than the minimum can never hurt at all.
The place where you *need* a space is between two tokens that would look like one token without a space e.g. "int i".
That's C. That's not the pre-processor, which has its own rules. And you can screw things up by not being careful with pre-processor macros.
Note that a macro definition such as ...
#define MASKIN(reg,mask,x) (reg = (mask & x)|(~mask & reg))
... is very dangerous. It can do quite unexpected things if reg, mask, or x are not simple variables names or constants.
For example, what if you call it as:
#define PIN(n) (1<<n)
MASKIN(sGPIO, PIN(1) | PIN(4), PIN(4));
... to set pin 4 and clear pin 1.
It's not going to do what you want AT ALL because after the macros are expanded you're going to have...
(sGPIO = ((1<<1)|(1<<4) & (1<<4))|(~(1<<1)|(1<<4) & sGPIO))
... which is going to be parsed as ...
(sGPIO = ((1<<1) |  ((1<<4) & (1<<4)))   |   (~(1<<1)  |  ((1<<4) & sGPIO)))
(sGPIO = (2 |  ((16 & 16)))   |   (~2  |  (16 & sGPIO)))
(sGPIO = (2 | 16)   |   (~2  |  (16 & sGPIO)))
sGPIO = 2 | 16  |  ~2  |  (16 & sGPIO)
sGPIO = (2 | ~2)  |  (16  |  (16 & sGPIO))
sGPIO = -1  |  16
sGPIO = -1
ALWAYS PUT PARENS AROUND MACRO ARGUMENTS IN THE EXPANSION
#define MASKIN(reg,mask,x) ((reg) = ((mask) & (x))|(~(mask) & (reg)))
Now it will do AND #-3; OR #16 as intended.  (or the AND might be with #-19, depending on the optimiser .. same thing)
The following users thanked this post: Zero999, Ian.M
Online Zero999Topic starter
  • 0999
« Reply #26 on: April 22, 2022, 05:38:09 pm »
I've sorted it thank you to everyone who posted here.
If the watchdog timer isn't reset. GP2 and GP5 pulse at 20% duty cycle at 1Hz and the other ports change to high impedance inputs, with the puil-ups disabled.
 * File:   main.c
 * Created on 14 April 2022, 18:47
//  Turns on an LED for 10 seconds after being triggered by a pushbutton.
//  GP0 = Pushbutton switch 1
//  GP1 = LED1
//  GP2 = Error
//  GP3 = Pushbutton switch 2
//  GP4 = LED2
//  GP5 = Error
// PIC12F509 Configuration Bit Settings
#pragma config OSC = IntRC      // Oscillator Selection bits (internal RC oscillator)
#pragma config WDT = ON         // Watchdog Timer Enable bit (WDT disabled)
#pragma config CP = OFF         // Code Protection bit (Code protection off)
#pragma config MCLRE = OFF      // GP3/MCLR Pin Function Select bit (GP3/MCLR pin function is digital input, MCLR internally tied to VDD)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#define _XTAL_FREQ 4000000      // oscillator frequency for _delay()
#define sGPIObits (*(GPIObits_t * volatile)&sGPIO)              // shadow port structure
#define MASKIN(reg,mask,x) ((reg = (mask & x)|(~mask & reg)))   // mask macro to select which bits to keep. Not thread safe but smaller.
//#define MASKIN(reg,mask,x) (reg^=(reg^(x))&(mask))            // mask macro. Slightly larger binary code, but thread safe.
// pin definitions
#define trigger1    GPIObits.GP0
#define trigger1_s  sGPIObits.GP0   // shadow trigger 1
#define LED1        sGPIObits.GP1
#define trigger2    GPIObits.GP3
#define trigger2_s  sGPIObits.GP3   // shadow trigger 2
#define LED2        sGPIObits.GP4
#define TRIS_set    0b101101        // configure GP1 & GP4 as outputs
#define TRIS_error  0b011011        // if WDT GP2 & GP5 are error outputs, which pulse 200ms at 1Hz
#define timeout1 (int)(10/0.008)    // 10/8ms
#define timeout2 (int)(10/0.008)
#include <xc.h>
#include <stdint.h>
volatile unsigned char sGPIO = 0;   // shadow register
unsigned short counter1 = 0;        // timer counter 1
unsigned short counter2 = 0;        // timer counter 2
void main(void) {
    if (!__timeout)             // If the watchdog timer healthy flag is not set
        OPTION = 0b11010010;    // configure Timer0:
                                //-1------ disable weak pull-ups on GP0, 1 & 3
                                //--0----- timer mode (T0CS = 0)
                                //----0--- pre scaler assigned to Timer0 (PSA = 0)
                                //-----010 pre scaler = 8 (pre scaler = 10)
                                // -> increment every 8us
        TRIS = TRIS_error;
        for (;;)                // pulse error outputs
            if (TMR0 >= 125)    // decrement counter every 125 * 8us = 1ms
                CLRWDT();                   // clear watchdog timer
                TMR0 = 0;                   // reset timer
                if (counter1) (counter1)--;
                else counter1 = 1000;                   // 1000ms period
                if (counter1 < 200) GPIO = 0b111111;    // 200ms on
                else GPIO = 0;
    OPTION = 0b10010100;        // configure Timer0:
                                //-0------ enable weak pull-ups on GP0, 1 & 3
                                //-----100 pre scaler = 32 (pre scaler = 100)
                                // -> increment every 32us
    TRIS = TRIS_set;            // configure TRIS
    GPIO = 0;                   // set all outputs low
    for (;;)
        if (TMR0 >= 250)        // timer exceeds 250 * 32us = 8ms
            if (counter1)       // decrement counter if not zero
                counter1--;
            else
                LED1 = 0;
                if (trigger1_s && !trigger1) // trigger changed from high to low & counter is zero
                    counter1 = timeout1;
                    LED1 = 1;
            if (counter2)       // decrement counter if not zero
                counter2--;
            else
                LED2 = 0;
                if (trigger2_s && !trigger2) // trigger changed from high to low & counter is zero
                    counter2 = timeout2;
                    LED2 = 1;
            GPIO = sGPIO;
            MASKIN (sGPIO,TRIS_set,GPIO);
return;
