Hi guys,
I have some questions to ask, I've been searching over the net to find the answer but w/o success. I've been searching this forum for answers but no success here, too. This forum looks like a good source of knowledge so i hope someone will come up with the answers.
I bought Hantek 6022be DSO and by looking at it and at the interface looks like there is no option to connect to it a Current Clamp (AC/DC CC-65 for example), do you know is it possible to connect current clamp to that dso?
On hantek 1008c you can from the drop-down menu on corresponding channel choose the current clamp as a input probe, but on 6022be there is no such option. So is that a matter of software only or? I see there are alternative software for that hantek dso, is it possible to connect cc using those softwares?
Since 6022be has dc coupling only, can you still use ac part of the current clamp? Can you make some sort of ac coupling externally?
Thanks.
