I am oscilloscope hantek dso 5102p turns on, enters all functions, updates firmware, does self-calibration. But do not perform measurements, your probe is inoperative dead. I decided to disassemble and saw. that line +5v was low about 0.98v . The probe terminal tester should have 5v frequency 1khz, but it is marked 0.5v . I decided to remove the 78r05 regulator and test it with load. ok. Then I injected 5v into the regular output alloy, the line remained 5v but a 50ma consumption and a component heating up appeared, and I could see a hole in it. Does anyone know what component this is? Because in the generic scheme I didn't find it. The 5volt line enters pin1 of this ci
