Hello Guys. Good day
I wanted to mix 4 1GHz digital signals to a single 4GHz signal.
Let's name them A, B, C, D
so every a nanosecond they pulse one time. And I plan to multiply the four input signals by 4.
So they will pulse 4 times per nanosecond and using a clock to time them.
So if the input in input A is A1, A2 the output is A1, A1, A1, A1, A2, A2, A2, A2.
Then,
A1, A1, A1, A1
B1, B1, B1, B1
C1, C1, C1, C1
D1, D1, D1, D1
with the clock will be A1, B1, C1, D1 in 4 times the input frequency.
Am I right there?
Thank you!
