Author Topic: Has anyone seen these two types of capacitors?  (Read 2071 times)
Offline RonFred2Topic starter
    • Biophysics Lab
« on: September 27, 2018, 03:35:22 am »
While sorting a box full of parts from the 1980's I found two capacitor types I have never seen before:
  • Glass bead looking thing measuring 1.5 nF (see photo)
    Tubular looking thing with outer coating like ceramic measuring 150 pF (see photo)
Can someone tell me what type of capacitor they are and best usage in design/circuit? Also do you think these caps are still good after 35+ years?
Offline ArthurDent
Re: Has anyone seen these two types of capacitors?
« Reply #1 on: September 27, 2018, 03:51:41 am »
Here you go.
The following users thanked this post: RonFred2
Online ataradov
    • Personal site
« Reply #2 on: September 27, 2018, 03:53:27 am »
The transparent one is a polystyrene film capacitor. They do age due to plastic shrinking, but it is still probably fine.
Tubular one is old-timey ceramic capacitor. Probably also works. But there is no real point in using either of them nowadays.
Alex
The following users thanked this post: exe, RonFred2
Offline floobydust
« Reply #3 on: September 27, 2018, 03:57:39 am »
The 152J is a polystyrene film capacitor 1,500pF 5%. Xicon manufactures them, available at Mouser.
They are for applications needing low dielectric absorption, and audio filters, timing use. Not so popular today because they are large size.
The tubular or "dog bone capacitor", usually have a large temperature coefficient to correct RF circuits over temperature. They were popular in Tektronix scopes through the 1980's.
Offline Benta
« Reply #4 on: September 27, 2018, 04:24:55 pm »
From what I've heard, polystyrene caps are no longer produced, as polystyrene film has been phased out. Replacement is polypropylene.
Offline chris_leyson
  • Country: wales
« Reply #5 on: September 27, 2018, 05:06:02 pm »
That radial leaded polystyrene cap is not as common as as the axial variety.
Offline schmitt trigger
  • Country: mx
« Reply #6 on: September 27, 2018, 05:21:16 pm »
That is correct. There was an article in one of the trade magazines, which indicated that the world's remaining polystyrene film factory had shut down.
That there were plenty of virgin film stock available, but that eventually, it would run out.
That article appeared perhaps 4 years ago...
Offline drussell
  • Hardcore Geek
« Reply #7 on: September 27, 2018, 05:48:10 pm »
They were available in a variety of temperature coefficients, including 0.
Offline Zero999
  • 0999
« Reply #8 on: September 27, 2018, 07:44:45 pm »
I believe the main reason polystyrene is no longer used for capacitors because poorer resistance to solvents, than polypropylene.
  • Country: mx
« Reply #9 on: September 27, 2018, 08:08:38 pm »
It was a very good dielectric, though.
I had once a PLL circuit with excessive jitter. I could not figure out why.
A personal anecdote: Out of sheer desperation, I replaced the loop filter's capacitor from a NPO ceramic to a polystyrene type.
The jitter diminished significantly.
One unknown fact about polysterene caps is that they have what appears to be a "polarity" band.
It is not actual polarity, but indicates which terminal is connected to the outermost foil.
You should connect that terminal to the closest potential to ground. Or in the case of my example, where one capacitor end is grounded, to ground.
That eliminates noise pickup in sensitive nodes.
Offline floobydust
« Reply #10 on: September 27, 2018, 08:24:49 pm »
Polystyrene are still in production, I get axial and radial Xicon parts from Mouser up to 10nF.
I still buy/use polystyrene for A/D integrator caps and high-end audio use, as only Teflon is a better dielectric. Once you use a few in an application where the dielectric's properties are important, then you easily see the differences.
The package melts easily and reflow is not the greatest for it, and it has relatively high self-inductance being a physically large part.
