Hey everyone,
So this is the situation: I was looking to acquire a cheap function generator, something to emulate low-voltage AC, mess around with the oscilloscope or otherwise play with a pulsing current without killing myself, that is either electrocuting myself from the wall or banging my head on the table trying to build a safe alternative from scratch. So I did what many electronics noobs do and looked through the Won Hung Lo section of Ebay. Ordered myself a function generator kit(what, for soldering practice and whatnot:
http://www.ebay.com/itm/291481351716)
What I needed next was a source of power, so I took a quick look at the listing and saw 4 power pins: +12, -12, +5, GND. I figured: Simple, just get a +-12 supply for the amp and use a 7805 for the micro. I went ahead and opened a listing (
http://www.ebay.com/itm/371117456686) and, seeing how this is a fairly low power device, I picked out the smallest, 1-amp option. Of course, before ordering I asked them if there were actually outputs for +12v and -12v, and they replied something along the lines of: "Yes, there V+ and V-, see picture!"
Of course, when I got the supply I was a bit disappointing. Turns out the only real ground is mains-earth, which is isolated from the DC side. V- is just that, negative. Not -12, but the negative for the +12. Oops. Anyhow, that leads to my question! I currently have a +12 switching power supply(the IC is a HT2203C) and no real means of easily getting -12v. My question is, what can I do to get the -12v output that I need, along with the +12v from the supply? Can I link two of these cheap supplies in series the same way it can be done with a bench supply? Or will I have to explore other options?
I included a picture of the supply below. Any tips, advice and insight would be greatly appreciated!
Thanks
