In Automotive Electronics, every 1/10 of Cent savings counts for resistors. ..
Therefore, cheap thick film technology, 5%, E 12 is preferred.
Using least possible different values and case sizes also saves money, due to lower storage cost.
Each additional magazine of the pick 'n place machine costs extra money.
Therefore, all of our engineers try to avoid special resistors or capacitors and try to reduce the variety, whenever possible. Design reviews support this cost reduction process.
Anyhow, in some places, even 1% thin film are still required: At A/D inputs, for sensors for temperature, fuel, pressure, etc.
LCDs often need precise R divider ladders for the different phases.
Also LEDs require 1% resistors for exact initial luminosity because up to 20..30 LEDs in a cluster instrument need to give a totally even illumination. The LEDs themselves come sorted for equal forward voltage, and additionally for equal lumonisity classes, therefore each of these LED selections require one special resistor value, 1%.
Therefore, these "odd" components are sometimes required, even in such extremely low cost apps.
Frank
