Author Topic: Switch terminology  (Read 272 times)
Offline msknight
    • My pages
Switch terminology
« on: June 21, 2021, 06:45:58 am »
I know what I'm looking for... I just can't work out the terms I need to find it.
On a joystick, I want a button/switch to mount on/in the joystick board, which allows me to invert an axis. Under normal operation, feed 1 goes to A and 2 goes to B. When "switched" feed 1 should go to B and 2 should go to A. Hence effective inverting the axis.
But I can't work out the terminology I need for that kind of switch. Any ideas please?
If god had meant for humans to solder, she'd have given us three hands.
Offline Le_Bassiste
Re: Switch terminology
« Reply #1 on: June 21, 2021, 08:04:59 am »
An assertion ending with a question mark is a brain fart.
The following users thanked this post: msknight
Offline Ian.M
« Reply #2 on: June 21, 2021, 08:11:21 am »
You need a DPDT (double pole, double throw) switch, also known as 2P2T switch.  See https://components.omron.com/pole-throw for explanation of poles and throws.
Wire it as a reversing switch, i.e. cross link pole A NC to pole B NO, pole A NO to pole B NC, then run the pair of connections you want to reverse through the switch, on one side connecting both to the A and B COM terminals, and on the other to the two linked pairs of NO and NC terminals.
If you want to use a pushbutton it will need to be a latching switch, not a momentary one.
Online jpanhalt
« Reply #3 on: June 21, 2021, 09:38:48 am »
There are 2 basic configurations of DPDT switches.  Some have a center position ("off").   Others just switch between the two options.  In addition, some hold the new position (i.e., there are 2 stable states) ; others are momentary on one state.
I suspect you want an on-on version.  Maybe this will do: https://www.digikey.com/en/products/detail/nkk-switches/YB26WCKW01/2107465
EDIT: make that on/on "or on/mom"  (momentary)
If size is an issue. a single SPST momentary switch will probably be smaller and that could operate a DPDT relay.
« Last Edit: June 21, 2021, 07:16:39 pm by jpanhalt »
