Author Topic: fluke style on a scope posible?  (Read 1485 times)
Offline Mark_CTopic starter
« on: December 09, 2016, 06:41:55 pm »
Hi All,
My first post here.
I'm an Electrical Engineer try to become an Electronics Engineer by self study. :box:
Learnd A LOT here and today I actualy solved a cable (150 meters) error at work with my DIY TDR
from w2aew on my realy nice home made PCB....but now a need a help/hint.
my Fluke FC3000A Current clamp, that realy sucks, gives me a really nice pic
http://i876.photobucket.com/albums/ab322/markcremer/Graph_01_zpsm7ljeddo.png
and my to 1104 upgraded Rigol that I really like give only AC Waves with my current clamps. (Chinees Hantec) and that sucks.
and the waves that sucks....
is it a setting  :-// or do i need a circuit to get the Rigol wavesgraph te  becomes like de the fluke graph... (stacked values)
thanks in advanced.
Mark
« Last Edit: December 09, 2016, 07:25:02 pm by Mark_C »
Offline daveshah
  • Country: at
    • Projects
Re: fluke style on a scope posible?
« Reply #1 on: December 10, 2016, 09:28:58 am »
If you only need to see peak values rather than RMS you could probably put the scope in "peak detect" mode or similar and use a slow timebase, and just look at the top or bottom "boundary"
« Reply #2 on: December 10, 2016, 06:59:03 pm »
Well I tried a bridge rectifier to make the signal dc that worked only now ...
the rectifier needs a bout 600 mV to open so my reading start also at 601 mV (its about 6 Amps AC)
so I mis the first 6 Amps....Is there a way to boost the ac voltage 10 times...so Ill have 6000mV.
than I will step down 10 times in the dc circuit.
for measuring Mains its not need to exact. 0,5 amps is fine in a range 0 to 100 amps.
Thanks
