Hello everyone,
I "just" started using the HC-05 Bluetooth module and I'm having some issues. Unfortunately no one else seems to have this issue :/ If I enter AT mode (38400) I can send almost all AT commands and I will also get an answer from the module. Or to be more precise I get an unlimited amount of answers until I press Enter a second time.
I tried different commands, different settings, different serial terminals and also different HC-05 modules from different suppliers. I keep seeing the issue. There might be a super easy solution to this but I was not able to find it
Also if I type AT+NAME? and hit Enter the module does not respond and simply resets itself...
Please let me know if you have any ideas
Thanks for your help!
Robin
