Author Topic: Advice on an amplifier topology  (Read 760 times)
Offline TheBaconWizardTopic starter
« on: July 01, 2018, 10:21:50 am »
So I'm learning about various amplifier types and came upon the following interesting circuit
I wouldn't mind building something similar. But I don't quite understand the relationship between the two mosfets in each cell, what is the purpose behind strapping them together in this fashion?
Re: Advice on an amplifier topology
« Reply #1 on: July 01, 2018, 01:21:55 pm »
The clue is the voltage rails (±600V = 1200V overall) and the VDSmax rating of the transistors (800V). As this is a class B topology it's quite possible for the entire rail voltage to appear across either the top half or the bottom half. Setting up the output transistors like this lets them share the voltage drop so that each pair might see 1200V, but each transistor will only see 600V and so stay within its VDSmax rating.
The following users thanked this post: TheBaconWizard
