Author Topic: Headphone Testing Help  (Read 9212 times)
Offline wardenclyffeTopic starter
« on: May 18, 2011, 02:51:08 pm »
A friend of mine asked me to repair some headphones the other day. The only problem was general wear where the wires come out from the end of the jack. I cut the jack off and went to add a new one but I couldn't figure out which wires were the left and right channel. I tried to pull the rubber coating off the the old jack to figure out how they were soldered on but goofed it up so badly it was useless.
I know very little about audio signals so my question is how I can best test the headphones to figure out which side is left and right. I am assuming I can feed in a sine wave in the audio range and listen for a tone in headphones but I don't want to damage them in the process. Is there an amplitude limit I should stick to? Some other places have suggested putting a 1.5V battery across the terminals and listening for a pop in the headphones, but I am skeptical of that approach. Any suggestions would be much appreciated.
Offline JohnS_AZ
    • About.me
Re: Headphone Testing Help
« Reply #1 on: May 18, 2011, 03:33:13 pm »
I've done the 1.5V battery thing many, many times.
I'm either at my bench, here, or on PokerStars.
Offline Zero999
  • 0999
« Reply #2 on: May 18, 2011, 04:29:18 pm »
The 1.5V battery will work but don't do it with the phone in your ear - it's really loud.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: May 18, 2011, 04:49:21 pm »
you can sometimes use you meter in low ohms mode
Offline Zero999
  • 0999
« Reply #4 on: May 18, 2011, 04:53:01 pm »
That won't tell you which is left and which is right though.
Offline Simon
  • Global Moderator
« Reply #5 on: May 18, 2011, 04:59:24 pm »
it will if you listen for the crackle ! not sure if it works on digital meters though
Offline pmrlondon
    • Phil's personal pages
« Reply #6 on: May 18, 2011, 06:03:40 pm »
There's probably no surer way than the ones mentioned. Sometimes the core wire colour is a hint but it is by no means standard. Last pair I had to change the plug on had enamelled wire - that was a bit of a pain, but I think the colours helped there.
Offline ziq8tsi
« Reply #7 on: May 18, 2011, 06:04:08 pm »
It does, but you will probably need to be wearing the cans to hear the low test currents from a DMM.
One of the non-intuitive features of unamplified analog meters was that on the lowest ohm range they put a significant fraction of an amp through the device under test, even at only 1.5V.  Enough to make an incandescent torch bulb glow dimly for instance, and certainly make loud clicks on a headphone.
Whereas on the highest ohm ranges the open-circuit voltage could be 9V, but the short circuit current would be only microamps.
Offline Simon
  • Global Moderator
« Reply #8 on: May 18, 2011, 06:12:16 pm »
you have just elaborated on my point
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #9 on: May 19, 2011, 12:55:05 am »
you repair earphone and you dont have anything to play from? radio? cd player? pc with sound card? very odd. use a battery then, scratching the wire on it, u'll hear something.
The Ultimatum of False Logic... http://www.soasystem.com/false_logic.jpg
Offline Ronnie
  • Country: ph
  • Stimulating your Ears
« Reply #10 on: June 22, 2011, 01:48:02 am »
Connect a capacitor in series with the 1.5 V battery to avoid shorting it continuously by the speaker coil. During transient speaker coils like inductors are open circuit but will be short circuit after several µs or ms (depending on the resistance of the circuit).
Offline vk6zgo
« Reply #11 on: June 22, 2011, 04:00:55 am »
Do the headphones have markings to show which is physically L or R?
If so, just keep trying pairs of wires  using the method posted by others above,until you find ,say, the L one.
The other pair are the R.
But,wait--there's more! The above finds the two sides,but it doesn't necessarily get them phased correctly.
The only easy way to do this is if you can somehow see the diaphragms.
You then put the two pairs in parallel,& do the ohmmeter test as before.
If both diaphragms move in the same direction,they are phased correctly.If not,reverse one connection.
The other(harder) way is to use a tone or mono music,again with the earpieces parallelled,& see if you can hear the difference.
The wrong way round should subtract,the right way,add,but I think you may need "Golden ears" to notice. :)
VK6ZGO
Offline Simon
  • Global Moderator
« Reply #12 on: June 22, 2011, 05:28:46 am »
VK6ZGO
The common earth is usually quite obvious on g
headphones
Offline vk6zgo
« Reply #13 on: June 22, 2011, 07:16:42 am »
You are right,that is the normal configuration.
I was led astray by the fact that fact the stereo phones that I set up for mono use for Ham radio are odd ones which use two separate pairs.
My first HF receiver was quite happy with the mismatch of two earpieces in parallel,but the transceiver I bought later,wasn't,so I connected them in series.
I couldn't have done that if it had one wire always commoned.
VK6ZGO
PS:- Come to think of it,of course I could have connected them in series, just by ignoring the fixed common!
It isn't how I wired them,though as they did have separate pairs.
« Last Edit: June 22, 2011, 07:45:36 am by vk6zgo »
Offline pmrlondon
« Reply #14 on: August 14, 2011, 08:35:35 am »
Self-followup time:
I've forgotten how I stripped the enamel - and the same thing has just cropped up again. Any hints on how to get (soldering-proof) enamel off wires?
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #15 on: August 14, 2011, 08:57:32 am »
Enamelled wires are hard to solder...
sometimes I had success with a VERY short immersion in a VERY hot solder pot,  sometimes I was capable of burning the enamel with the flame  of a gas lighter,  sometimes the VERY hot tip of the soldering iron was enough.
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
HLA-27b
  • Guest
« Reply #16 on: August 14, 2011, 09:03:49 am »
Rubbing some fine sandpaper helps a great deal. A lot less messy than burning with flame.
Offline Psi
« Reply #17 on: August 14, 2011, 11:03:27 am »
I normally just scrape them carefully with a sharp craft knife or scalpel rotating the wire as i go.
You can normally see where you've scraped off the enamel off because the color changes.
However if the wire is really thin, (eg lots of strands all enameled separately), then things get tricky.
A flame is probably the easiest way.
Offline ejeffrey
« Reply #18 on: August 15, 2011, 04:56:45 pm »
[quote author=pmrlondon link=topic=3452.msg59188#msg59188
[/quote]
At home I use a scalpel.  At work when I need to strip a long length, or very delicate wires with very tough coatings I use formic acid.  Watch out for fumes... it isn't particularly dangerous as chemicals go, but just a whiff is like snorting vinegar.
