Author Topic: Identify a component  (Read 3585 times)
Offline rylimTopic starter
« on: July 25, 2016, 05:30:29 pm »
Hi, I'm a newbie in this forum, and I'm seeking help to identify a component inside the red circle of picture below.
Offline pyroesp
    • Nicolas Electronics
Re: Identify a component
« Reply #1 on: July 25, 2016, 06:25:47 pm »
Looks like some sort of voltage regulator, you seem to have a 10µF 25V capacitor to the output (if I'm not mistaken).
Is there any indication on the PCB of what the voltage could be ? Maybe following the trace can lead to some silkscreen text...
I suppose you don't have or can't find the schematic of the board ?
Offline Neilm
« Reply #2 on: July 25, 2016, 06:30:11 pm »
Could be a PBSS5330X - a 30V PNP transistor. Data sheet http://www.nxp.com/documents/data_sheet/PBSS5330X.pdf. Small P indicates made in Hong Kong
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
The following users thanked this post: rylim
Offline Signal32
« Reply #3 on: July 25, 2016, 06:36:07 pm »
Seems you are right, looks very similar to http://www.aliexpress.com/item/PBSS5330X/32532041468.html (2nd pic)
Offline pyroesp
« Reply #4 on: July 25, 2016, 06:40:56 pm »
I was wondering about that, nice to know.  :-+
« Reply #5 on: July 26, 2016, 05:15:03 am »
Unfortunately I don't have the PCB schematic, and I believe the voltage is around 12Vdc
I'm wondering how did you figure out it is a 30V PNP transistor? I have been googling for that component, as well as looking up many transistor coding books.
« Reply #6 on: July 26, 2016, 05:17:44 am »
Thanks for the time of posting the link.
By the way,  the transistor in the picture is P02, whereas mine is P06 and I'm wondering if it makes any different?
« Last Edit: July 26, 2016, 05:53:04 am by rylim »
Offline Signal32
« Reply #7 on: July 26, 2016, 08:02:42 am »
The 2nd marking isn't mentioned by the datasheet. I'm thinking it's either a date code or serial number. So, no, yours is just part of a different batch.
Offline Refrigerator
  • Country: lt
« Reply #8 on: July 26, 2016, 08:32:31 am »
"Q9" on PCB next to the part means it's a transistor, now you can use a diode tester to test it or use that as reference point when looking for a replacement.
Q or T means a transistor. U or IC means an integrated circuit, if this was a voltage regulator it would be marked that way.
Edit: use this site ( or similar ) when looking for SMD parts : http://www.s-manuals.com/smd .
« Last Edit: July 26, 2016, 08:39:37 am by Refrigerator »
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline PA4TIM
« Reply #9 on: July 26, 2016, 10:18:06 am »
These sites can help:
http://www.systek.ru/marking.php?marking=4e
Edit, I now see the link is already given.
I have to do this almost every day and although  I'm getting good at it, it still is no fun.
If you google it is handy to add : smd marking  to the search parameters. Also the type of package can help and sometimes datasheet.
fi something like : AH sot-89 smd marking datasheet And sometimes it helps to add things like mosfet.
Could be a 2SD2413 that has marking 1S for sot-89 then 06 could be the years code ?
Besides that I use a pdf from a book that is over 2000 pages and states all smd markings. It is a commercial yearly publication from Turuta. Called the smd-codes databook.
There also is a free pdf named the smd codebook
« Last Edit: July 26, 2016, 10:48:24 am by PA4TIM »
Offline djQUAN
  • Country: ph
    • My DIY website
« Reply #10 on: July 26, 2016, 12:40:04 pm »
now you can use a diode tester to test it[/url] .
Not going to work in this case as the part is blown and cracked, split in half :)
Offline Neilm
« Reply #11 on: July 26, 2016, 06:24:43 pm »
Googled " SOT-89 marking p1S". Quick sort through the results concentrating on manufacturer sites
« Reply #12 on: July 29, 2016, 08:53:58 pm »
Many thanks to all of you. I have ordered the component (PBSS5330X), and hope that the label of second line is the date of production
