I think that would depend of the type of element.
Something like an electric stove element - no.
Quartz element - basically a light bulb so maybe.
ceramic heater - basically a PTC (Positive Temperature Coefficient) resistor - don't know
Here in North America, the maximum you can pull out of a typical circuit is ~1800 watts and you many heaters are rated for 1500W so you won't see much in the way of surge currents or you'll blow the breaker.
Ed
Electric stove element internally will be a dull red heat when in use, so quite a big change in resistance cold to hot, that the outside is not glowing is not relevant to the inner in the insulating magnesia powder fill.
Quartz element a really big change, seeing as it goes from cold to bright cherry, giving off a fair amount of visible light.
Ceramic non PTC heater is more or less just resistive and only a slight tempco, but still there in spades.
PTC heater whacking great big current till it gets near the transition temperature, then the resistance varies wildly till losses are balanced by dissipation, which is why you get the cheap glue guns with a PTC that are operable from 90VAC to 260VAC with absolutely no changes, they just run a tiny bit hotter at 250VAC, and tend to fail eventually by blowing the PTC element to powder.
I just tested an ancient hot ribbon style heater (~1100W) and a new PTC ceramic heater (~1500W). Neither had a visible startup surge when measured with a Kill-a-watt. The ratings on the PTC heater are interesting. It's actually 1500W @ 25C and 1650W @ 0C.
I also have a few stove elements that I use for test loads. Their ratings & measurements are:
240V, 1325W (therefore, 43R5 hot), measured 43R0 (cold)
" , " 44R7 " (two allegedly identical elements)
240V, 2350W (therefore, 24R5 hot), measured 24R0 (cold)
The cold measurements were made with a 4-wire milliohmmeter with a 0R1 resolution and 0R0 reading when the leads are shorted.
IOW, no surges in these items. Do you have any test data to share?
Ed
