Author Topic: Heathkit IT-11 Capacitor Checker  (Read 3810 times)
Offline SgtRock
« on: May 10, 2011, 12:08:54 am »
Dear EEVBees:
--As Gomer Pyle USMC used to say; " Heyelp, Heyelp, Heyelp."
--I am getting -0.16VDC at pin 8 of the 6BN8 instead of -0.22VDC as per the schematic. I have checked all voltages, cleaned all switches, checked or replaced, all components, verified wiring, substituted tubes and am tearing out my remaining hair. See link to schematic below.
http://www.heathkit.nu/IT-11_schematic_1600.png
--(1) Why would I get -0.16VDC and not -0.22VDC?
--(2) What alteration could I make to get -0.22VDC?
Your suggestions are humbly solicited.
Clear Either
Offline vk6zgo
Re: Heathkit IT-11 Capacitor Checker
« Reply #1 on: May 10, 2011, 01:10:12 am »
The voltage is a very low one in Vacuum tube terms,& depending on what they used to read it,may be really either
nearer or closer away from your reading.
Does the tester work with this voltage? If so,ignore it & say that it is just due to component variations between  the
one they tested for the book,& your one.
You could test R6,as high value resistors are prone to increase of resistance with age.
VK6ZGO
