Author Topic: Heatsink for GSIB-5S  (Read 863 times)
Offline dcbrown73Topic starter
« on: September 07, 2019, 09:23:29 pm »
Hey all,
For the life of me, I cannot seem to locate heatsinks that are made for the GSIB-5S package rectifiers.
Is there a standard type of heatsink package for these or do you just "make due"?
Why exactly do people feel I should have read their post before I responded?  As if that was necessary for me to get my point across.
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
Re: Heatsink for GSIB-5S
« Reply #1 on: September 07, 2019, 09:28:12 pm »
Hi for reference are you looking for something like this? It is from a ATX power supply.
https://www.techpowerup.com/review/corsair-ax760i/4.html
My point is as long as it fits the heasink ( check datasheet measures) and the heasink it is properly designed for the application, it could be a custom design, an existing one and maybe drill a hole.
« Last Edit: September 07, 2019, 09:35:12 pm by malagas_on_fire »
If one can make knowledge flow than it will go from negative to positve , for real
« Reply #2 on: September 07, 2019, 09:36:58 pm »
Yes, something like that would be perfect.   I just cannot seem to locate any heatsinks that are similar.  Most are for TO-220, TO-3, or for CPU/GPUs.
I've got a bunch of all different sizes heatsinks for mosfets / voltage regulators and similar, but the gap where you bolt it to the part isn't wide enough for the rectifier.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #3 on: September 07, 2019, 11:04:34 pm »
Sorry for my delay i've searching only on fleebay and got more results using dimensions or supplying the to220 in the search. here is an example which you could drill a hole:
 https://ebay.us/WwmtBD
or use this as reference;
https://ebay.us/cRO7qo
