I hope this isn't the wrong spot to put this. Most forums I have joined have had a welcome new person section. I did not see such a section here.
I just signed up.
I have a multimeter that has quit working correctly. It was shorting between the volts and ohms range on the selector switch. Attempts to clean the conctats have made it worse. Now the mater is useless. That is fine, becuase I have already purchased a replacement. The new Meter is an Extech 330. I was glad to see Dave do both of these meters against each other in his shootout.
I have had the meter since about 2007. It was purchased with part of a tool kit/set that I got through my Aircraft Mechanic School.
Throwing the old meter into the trash just doesn't seem right.
What would anyone suggest I do with my old Elenco M2625.
