Author Topic: Is it OK to put 0603 resistor on the 0402 pads?  (Read 5485 times)
Offline Iron DowneyTopic starter
  • You have to do the best with what God gave you
    • PCB & Assembly manufacture
« on: May 16, 2016, 09:57:45 am »
I made a mistake for the package of the resistor. The pads on the board is 0402, I bought 0603 and I have assembled 1 piece now. See the attached picture. It looks fine, but I'm a little wonder if it would have some bad effects?
PCB and PCBA engineer on http://en.zfpcba.com/, a professional PCB and assembly manufacturer
Offline nour
  • Country: sa
  • calm down, it is just a smoked oPamP!
Re: Is it OK to put 0603 resistor on the 0402 pads?
« Reply #1 on: May 16, 2016, 10:22:23 am »
That looks perfectly fine to me  ???
if what I have wrote doesn't make sense for you or you think there is something wrong, please correct me, I am still beginner and what I know probably less than what you know
Online Psi
« Reply #2 on: May 16, 2016, 10:28:41 am »
It will work fine for one-off stuff
Offline m98
« Reply #3 on: May 16, 2016, 12:25:34 pm »
Wouldn't expect any problems.
Offline Neilm
« Reply #4 on: May 16, 2016, 06:49:28 pm »
About the only problem I can think of is that it will work fine - but if you build one with the smaller resistor you find that one of the parts is out of specification - most likely dissipating too much heat. What you have here will be OK, but when you make one with the small component remember to check none of them are getting too hot.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
The following users thanked this post: Iron Downey
« Reply #5 on: May 17, 2016, 07:52:15 am »
The boards work fine, just not in good look. I have accpeted it O0
