Author Topic: Is Radio Shack Rosin Core Solder, Multicore?  (Read 6010 times)
Offline salilTopic starter
« on: April 06, 2014, 08:24:24 pm »
linky:
http://www.radioshack.com/product/index.jsp?productId=2062711
I can't seem to find out if Radio Shack brand solder is multicore.  The only reason I'm considering Radio Shack brand is because I know for a fact that it's in-stock nearby and I need it today.  Any ideas?  Fry's and Radioshack are nearby but close in a few hours...  Suggestions are greatly appreciated.  Thanks.
Offline Skimask
Re: Is Radio Shack Rosin Core Solder, Multicore?
« Reply #1 on: April 06, 2014, 08:28:50 pm »
And you surely will never find out from the person behind the counter.
You:  I need solder.
Person behind counter: What?
Why exactly do you think you need multi-core solder?
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline Jarrod Roberson
« Reply #2 on: April 06, 2014, 08:34:30 pm »
Radio Shack is like a bad Saturday Night Live sketch that has gone on for way too long!
It used to be like a candy store, now it is a sad parody of itself from 25 years ago.
Thankfully we have two Fry's Electronics here, one near my house, and one near my work!
« Last Edit: April 06, 2014, 09:06:42 pm by Jarrod Roberson »
« Reply #3 on: April 06, 2014, 09:00:32 pm »
Haha, I know that's why I'm asking here.  The last time I asked someone a question at Radio Shack I had to explain to them what a potentiometer was.  Anyone know of any multicore solder that a local store like Radio Shack, Fry's, Home Depot, Menards, etc. sells?  I'm in the Chicago, IL area (USA).  Thanks.
Offline rexxar
    • Forever Tinkering
« Reply #4 on: April 06, 2014, 09:16:16 pm »
No, it's single-core.
Why is it critical that you have multi-core solder?
Online IanB
« Reply #5 on: April 06, 2014, 10:41:33 pm »
Multicore is a proprietary brand name and is going to be legally protected. If it doesn't have the Multicore logo on the packaging it is not Multicore. That's especially true if it has some other brand on the label.
(In case it helps, it is impossible to find Multicore solder in retail shops in the USA. It is very difficult to find it online either.)
Offline miguelvp
Offline mariush
« Reply #7 on: April 06, 2014, 10:58:10 pm »
What's wrong with Digikey?
Multicore solder on Digikey: http://www.digikey.com/product-search/en?FV=fff40014,fff80076,fffc0052
Online IanB
« Reply #8 on: April 06, 2014, 11:16:58 pm »
OK, to be specific Multicore with the Savbit alloy. That only seems to be available in or from the UK.
Offline mariush
« Reply #9 on: April 07, 2014, 12:09:57 am »
Well, that looks like 50 Tin 49 Lead 1 Cu. Doesn't seem that special to me (I get that the 1% Cu helps).
Farnell's US version of the site has it but you pay 20$ per order to get them for you: http://www.newark.com/webapp/wcs/stores/servlet/Search?catalogId=15003&langId=-1&storeId=10194&gs=true&st=savbit
Online IanB
« Reply #10 on: April 07, 2014, 12:33:14 am »
Interesting. I didn't know it was approximately 50/50 tin/lead. But whenever I have used it it has worked very well. It has good wetting properties, it flows and fills the joint quickly, and it leaves a nice shiny surface.
I think there may be a newer composition of 62 tin, 37 lead, 1 silver. But the information I can turn up is vague on that.
Offline mariush
« Reply #11 on: April 07, 2014, 01:01:50 am »
If you check the newark link and click on the pictures and zoom them  (Ctrl+ scroll wheel in firefox) you can see it says 50/49/1 on the label.
Also, you can check the safety data sheet on a product page, for example see this one: http://www.farnell.com/datasheets/369125.pdf
Declaration of ingredients according to EC/1907/2006:
Hazardous components CAS-No. EINECS ELINCS content Classification
Tin 7440-31-5 231-141-8 40 - 50 %
Lead 7439-92-1 231-100-4 40 - 50 %
Rosin 8050-09-7 232-475-7 1 - 5 % Xi - Irritant; R43
Copper Metal 7440-50-8 231-159-6 1 - 5 %
Offline Monkeh
« Reply #12 on: April 07, 2014, 01:23:42 am »
Except when it is actually Multicore solder but it's branded Multicomp.
Online IanB
« Reply #13 on: April 07, 2014, 01:33:03 am »
I also found this datasheet listed under Savbit, and it's different:
http://www.farnell.com/datasheets/1763379.pdf
Offline mariush
« Reply #14 on: April 07, 2014, 01:53:45 am »
That one's for 62/36/2 I think ... if 362 isn't the name of the flux formula. Anyway, this one's with Silver (Ag), not copper. I guess this one is targeted for surface mount stuff, which has silver in the terminals sometimes.
Offline Monkeh
« Reply #15 on: April 07, 2014, 01:56:36 am »
362 is the flux, yes.
Offline eKretz
« Reply #16 on: April 07, 2014, 05:56:37 am »
I have some Radio Shack solder that is multi core. I just sharpened up a set of ultra flush cutters and was doing test cuts on some .031" solder and could clearly see the multiple flux cores under 10x magnification.
Offline eKretz
« Reply #17 on: April 07, 2014, 06:12:53 am »
In point of fact here are some quick photos:
Edit: Not real sure if the OP was asking whether it was Multicore brand name or just multi core solder.
« Last Edit: April 07, 2014, 09:21:35 am by eKretz »
